  1. Kélvin
    Apr 2021
    Brazil
    Hello.
    Here this error appears.
    script error:there is no function named "lwlibavvideosource"
    [Attachment 58328 - Click to enlarge]
    - error
    [Attachment 58329 - Click to enlarge]
    - script
    What is going wrong?
    I got this code here in the Forum.
    I want to use it in a video.
  2. You need to download the LSMASH package and put LSMAHSource.dll in AviSynth's plugins folder. You will also need to download defreq and put defreq.dll in AviSynth's plutins folder. And TNLMeans.
    http://avisynth.nl/index.php/LSMASHSource
    http://avisynth.org.ru/defreq/defreq.html
    http://avisynth.nl/index.php/TNLMeans
    Note that defreq is only available in a 32 bit version (as far as I know). That means you will have to use 32 bit AviSynth, 32 bit AviSynth filters, and a 32 bit player/editor/encoder. If suggest you use AviSynth+ rather than the original AviSynth.
  3. Kélvin
    Apr 2021
    Brazil
    I did everything.
    Now this error appeared
    [Attachment 58330 - Click to enlarge]
    [Attachment 58331 - Click to enlarge]
  4. Don't translate false to falso, and show to mostrar!
  5. Kélvin
    Apr 2021
    Brazil
    OK!
    new mistake now
    [Attachment 58334 - Click to enlarge]
  6. If you look at the instructions for defreq() you'll see that it requires fft3d.dll
    http://www.fftw.org/
    Put the 32 bit version in C:\Windows\sysWOW64\, the 64 bit version in C;\Windows\System32.
  7. Kélvin
    Apr 2021
    Brazil
    How crazy.
    But this time it worked. Thank you.
  8. The fft3d libraries are used by many AviSynth filters (and lots of other free software) so it's good to have them.
