Hello, thanks in advance for any help. I'm trying to deinterlace an anime movie called SIN but my usual method of deinterlacing isn't working for this particular movie.
This is my current script and the one that usually works. I tried qtgmc just to see if it would work but the default settings didn't work and I don't know enough about it to know which settings to tweak.
Code:directshowSource("F:\Video\SIN THE MOVIE\SIN THE MOVIE_t01.mkv", fps=29.970, convertfps=true) #Source is vfr tfm() tdecimate()
Sample
Results 1 to 9 of 9
Never use DirectShowSource(). Use LWlibavVideoSource() instead. Will look at the sample...
The sample is field blended but there are tears about 1/4 and 3/4 down from the top of the frame. If you crop away those sections you get a pretty clean result from
There still a little blending from some temporal noise reduction in the source.Code:Mpeg2Source("SampleAnime.d2v", Info=3) Crop(0,120,-0,-120) QTGMC(preset="fast") SRestore(frate=23.976)
Obviously, that's not an acceptable solution. I don't think there's a way to get SRestore() to only use the center part of the video for its analysis.
Another way to approach this is to manually select frames:
That works for a while (see the panning shot that starts about 2.5 seconds into the video) but breaks in the pattern mean you'll have to work in sections.Code:Mpeg2Source("SampleAnime.d2v", Info=3) QTGMC(preset="fast") SelectEvery(5,2,4)Last edited by jagabo; 9th Apr 2021 at 09:43.
Out of every 5 group of frames, keep frames 2 and 4, discard frames 0, 1, and 3.
[QUOTE=MysticFTW;2616353I think i'm just gonna go with your first script without the 240p crop lol.[/QUOTE]
You're losing half the picture with that script though! -
Oooh no I'm NOT using the crop from that script so it'll be the full image.
Just a normal crop
Crop(8,4,-8,-0)Last edited by MysticFTW; 9th Apr 2021 at 10:44.
Deinterlacing
By jseo13579 in forum EditingReplies: 25Last Post: 13th Oct 2019, 16:33 -
Need help with PAL deinterlacing
By ziggy1971 in forum Video ConversionReplies: 14Last Post: 30th Sep 2019, 01:53 -
Deinterlacing + resizing: is it possible to do it better than this?
By Bencuri in forum Video ConversionReplies: 33Last Post: 2nd Sep 2018, 12:32 -
help old anime dvdrip .
By fulmanful in forum DVD RippingReplies: 9Last Post: 24th Oct 2016, 17:26 -
Anybody know where this anime is from?
By -Habanero- in forum Newbie / General discussionsReplies: 5Last Post: 5th Aug 2016, 16:57
