Results 1 to 12 of 12
  1. Kélvin
    Apr 2021
    Brazil
    Hello guys, I'm Brazilian, I really wanted to learn how to use AviSynth. I don't know anything. I wanted to learn from scratch.
    Could someone with patience help me?
  2. Look at Similar Threads links at the bottom of the page.
  3. Kélvin
    Apr 2021
    Brazil
    none of the topics helped me.
    Here in Brazil there is no tutorial.
    I have no intention of creating or editing script. I want to know how to use the codes. Where to put it. How to test. And how to save the result.
  4. kelvin,,
    Try MeGUI. It creates the Avisynth scripts for you, but they can be edited or you can create them yourself etc.
    For me, MeGUI was a way to ease into learning Avisynth, because MeGUI doesn't expect the user to know any6thing about it.
  5. Windows only.
    You might like to have a look at Film9 which is a basic 'front end' for Avisynth for cleaning up film and video.
    This won't do everything avisynth will do, just basic options available, but it may get you started, depending on what your content is and what you need to do.
    It will not help you learn scripts and avisynth, but it will do a few tricks that avisynth will do.
    Film9 is free.
    https://contact41766.wixsite.com/film9/home-1
    I have done a very basic tutorial on using Film9
    https://www.youtube.com/watch?v=jYPJLlsBMHM
    I would love to learn avisynth but my dyslexia means command line work, as required to master avisynth, is not for me.
    Fortunately I only want a few basic options.
  6. Kélvin
    Apr 2021
    Brazil
    kelvin,,
    I will do what you told me.
    I just downloaded MeGUI
    And now what do I do?
  7. Kélvin
    Apr 2021
    Brazil
    Originally Posted by super8rescue View Post
    Windows only.
    Film9 is free.
    Hi.
    A week ago I saw this video of yours on Youtube.
    I tried to learn but I couldn't.
    The language hindered me. I don't know how to speak English.
    I speak Portuguese, I'm here using the Google translator to talk to you.
  8. Kélvin
    Apr 2021
    Brazil
    I want to learn how to fix 2 mistakes in a series from the 70s.
    [Attachment 58309 - Click to enlarge]
    [Attachment 58310 - Click to enlarge]
  9. Originally Posted by kelvin View Post
    Hi.
    Obrigado por assistir meu vídeo.
    Lamento que você não entenda inglês.
    Boa sorte
  10. Kélvin
    Apr 2021
    Brazil
    Hi.
    Boa sorte
  11. Kélvin
    Apr 2021
    Brazil
    [Attachment 58311 - Click to enlarge]
    How to use these scripts in MeGUI?
  12. Originally Posted by kelvin View Post
    kelvin,,
    MeGUI is a program for re-encoding video and audio. It creates Avisynth scripts and uses them for encoding.
    Use the File/Open menu and open a video file. Hopefully from there MeGUI will prompt you to index your source file, you'll add the indexing job to MeGUI's job queue and run it, and then MeGUI's Script Creator will open so you can apply cropping and resizing to the video, if you wish to. Aand finally MeGUI will create the script for you.
    When you first run MeGUI, it might want to look for updates for many the tools it uses. If it does, let it update them.
    Don't worry about using third party scripts until you at least get that far.
