I have a programming background, but it's outdated and I know almost nothing about video. I'm on Windoze.
I have an old, fudgy-looking 630x430 .avi that I need to convert to .mp4; probably H264 or H265 although I don't know which is preferable.
I've tried some test conversions in handbrake & VideoProc.
I like the result from handbrake going to H264 with decomb and a light denoise and sharpen.
I like the result from VideoProc going to H264 with a light boost to brightness & saturation.
What I WANT, is all of it. (decomb, light denoise, light sharpen, brightness & saturation)
What is the best way? For a noob, that might mean the easiest way?
For some reason I don't understand, handbrake has no way to tweak brightness or saturation. And although VideoProc has a Sharpen filter, it has no way to tweak the filter strength, nor to add a video denoise. (VideoProc thinks that "denoise" means audio)
My chief idea, at the moment, is to "somehow" capture the ffmpeg parameters of both apps' conversions and combine them into my own ffmpeg command line. But how would I even capture their ffmpeg command lines?
Any suggestions?
You might try using AviDemux. It has lots of adjustable filters. The king of video filtering is AviSynth+. It has a steep learning curve because it's script driven. But with a programming background you'll probably take to it pretty quickly. There's also VapourSynth, the successor to AviSynth, which uses Python scripts.
Problem converting AVI to MP4
By haddoq in forum Video ConversionReplies: 3Last Post: 27th Feb 2019, 04:53 -
converting vbr mp4 file to cbr mp4
By brandcc in forum Video ConversionReplies: 13Last Post: 19th Jun 2017, 09:43 -
Converting from AVI to MP4 H264 Multichannel Audio, Interlaced
By Nedo in forum Video ConversionReplies: 31Last Post: 6th Jan 2017, 18:34 -
converting .mkv to .avi/.mp4 for a complete beginner
By celestial-cookie in forum Newbie / General discussionsReplies: 5Last Post: 19th Jul 2016, 17:47 -
Need help converting H.264 MP4 to AVI for DVD creation
By pcapone in forum Video ConversionReplies: 38Last Post: 27th Apr 2016, 11:13
