Results 1 to 11 of 11
    Sep 2010
    Argentina
    Hi guys I wanted to know what program do you recomend to burn some Bluray movies disc? I mean, I have my legal disc and I wish to make a full entire disc back on an blank BD50 and I wish to know if you can recomend burning program?
    Thank You in advance
    canada
  3. Member Seeker47's Avatar
    Jul 2005
    Imgburn.
    I had a kinda weird experience recently, which I am not well schooled enough in these things to explain. I went to burn something to BD-R disc: first on a very major media brand, then also on an "off" brand. (Optimum. But I think there may be more than one called Optimum . . . .) Imgburn was my first choice for doing this, although I had a couple other burning tools available. In neither case could Imgburn even see the blank media in the computer's LG BR burner, which is of relatively recent vintage and low-mileage in terms of use. So I then connected an external BR player via e-SATA -- also as it happens an LG, but a model from a couple years earlier, which may no longer be on the market. I think that one has never failed me on any task I've thrown its way, and it worked fine here with these two very same BR blanks, still using ImgBurn. So, any idea why the built-in LG burner kept telling me "No Media in the Drive" ?
    I also have a Pioneer external BR burner around here, which I've not even taken out of the box. Might be interesting to get a "third opinion" from that.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
    canada
    Imgburn hasn't been updated in a few years so your model which is newer isn't in imgburn data.
  5. Member Seeker47's Avatar
    Jul 2005
    That makes sense. I don't suppose there is any way for us end-users to update that database ?
    So, is Lightning UK off on other projects, or retired now ?
    In the meantime, when this comes up again I guess I can just use Burnaware, or something else . . . .
  6. It doesn't work like that and doesn't need to be updated like that.
    The issue there is between your drive and the media - assuming it can initialise other media. If it can't, your drive is just plain broken
  7. Member Seeker47's Avatar
    Jul 2005
    It burns DVD media just fine. It reads (commercial) Blu-Ray discs just fine -- can rip them with MakeMKV or Fab. Not yet sure whether it has problems burning certain BR blanks but not those of other manufacturers. One good test is apt to be whether Burnaware or another such program does not run into the same detection / burning issue, with blanks of the same kind. Will update that when I have more to report. As I said, one would think that the mileage on this drive is way too low for the laser to be failing.
    Good to hear from you ! What are you working on these days ?
    Feb 2006
    how fast are you burning your blu-ray discs ?? try slowing down your burn speed.
    especially when using cheap media.
  9. Originally Posted by Seeker47 View Post
    If you go into write mode and pop a disc in the drive, keep an eye on the various messages that show up in the status bar. They’re what the drive is returning.
    So it should go from something like...
    medium not present - tray closed
    (You eject the tray)
    Medium not present - tray open
    (You insert the disc and close the tray)
    Medium not present - logical unit is in process of becoming ready
    (Drive finishes initialising the disc)
    Ready
    Except it sounds like your drive can’t manage that last part and so gives up, simply reporting no disc is present.
    There’s no reason for any software to see it differently - bar dodgy drivers etc messing up your machine as a whole. ImgBurn defaults to SPTI, which is built into windows. No additional drivers are installed.
    Besides a few bits for a hobby, I’m not really doing programming anymore. I do still tinker with ImgBurn now and then. It’s probably about time I released a version that could at least identify Windows 10 correctly (purely cosmetic) ! I’m still very active on my own forum, but the optical market get smaller by the day
  10. Has anyone tried to burn a Bluray using Windows Media Player? Dell says you can using Win10 Windows Media Player. Other posts on Google says it can't be done. So which is it?
    Extraordinary claims require extraordinary evidence -Carl Sagan
  11. Member Seeker47's Avatar
    Jul 2005
    Ready
    I may have resolved this mystery. (?) This is the drive in question:
    https://www.quietpc.com/lg-ch08ls10
    I did not install it, came as existing equipment in this PC. It looks the same as in the image, except for also showing M-Disc on the tray, along with the Blu-Ray logo. Also obtained negative results using Burnaware. But if I've got this correct, this drive is only capable of reading BR (which is why it was able to rip commercial ones), though not of writing them. That was contrary to my assumptions. So there is nothing faulty with the drive itself. In order to have the full BR facility, I would need to replace the drive with one that also definitely burns BR -- just as I have it in a couple other PCs.
    Although the optical market may have shrunk, I still find value in it as a user. Most everything may be going over to streaming for content delivery, but I think people may come to regret not having more options for storage and backup.
