when i used tinra it didn't work so i'm staying with virtual dub. anyways when i use virtual dub the sound is not syncing with the video so i wanted to know how i would record the audio and then encode it back together with the video once its turned into avi.
Use TOTAL RECORDER - registered version - to record an audio of your rm movie.
Open real. Stop the movie. Open total recorder. Press the red recording button. Start the movie. Save when movie stops - total recorder will stop automatically.
Use VirtualDub or TMPGEnc to encode video and audio.
Getting the audio in sync is difficult and you may have to experiement with cutting your initial audio file using microsoft's own sound recorder but it can be done.
Experiment with a short extract of your movie and a short extract of the sound file to see how you need to cut the audio file.
mikeboo -
If you have copy of Goldwave, you can also record a live stream. Select Stereo Mixer out as record source.
SK
It wont work with shareware version you must obtain a registered version. The program costs us dollars twelve if downloaded from the web.
Just open both your program to play the video and total recorder, press the red record button on total recorder and play the video. The sound will be captured automatically.
Is there a capture utility like tunebite that will capture 5.1 audio?
By yoda313 in forum Capturing and VCRReplies: 5Last Post: 18th Dec 2015, 03:45 -
How to capture audio only
By bigbomber5 in forum EditingReplies: 2Last Post: 1st Sep 2010, 15:38 -
What about audio capture?
By Fryster in forum Capturing and VCRReplies: 3Last Post: 25th Dec 2009, 10:47 -
Old PC and want to capture TV audio, etc.
By cantthinkofanickname in forum Capturing and VCRReplies: 1Last Post: 21st May 2008, 14:33 -
How to - Capture DVD 5.1 Audio - Coaxial vs. RCA Audio
By JBredensteiner in forum Capturing and VCRReplies: 3Last Post: 13th Jul 2007, 13:46
