Apologies if the answer is obvious, but I'm clueless: I run my VCR's audio through my stereo receiver/amplifier. It's plugged straight into the outlet, no daisy chains. The issue is that when the VCR is plugged in, my phono and cassette players' audio drops significantly and I have to turn up the volume twice as high to reach the same sound level as when the VCR is not plugged in. What is causing this and how do I fix it?
Hello companda. Plugging in a audio source (VCR) to an input of a receiver should not affect the output level of other sources connected to the receiver. I suggest that you look carefully at the labeling on the jack panel of the receiver and be sure that you are plugging the VCR into a valid input, and not a output such as a tape output. sometimes the labeling on these crowded jackplates can be close to two or more jacks, leading to confusion on which jack performs which function- especially when you look at it upside down, as is often the case when you pull a component slightly out of a shelf and look down at it from above. Hope this helps.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
Advice on low capture audio volume
By silva455 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2020, 16:41 -
MPDN very low volume
By Blackdragonbird in forum Software PlayingReplies: 0Last Post: 18th Aug 2018, 11:55 -
Premiere pro CC. Import 5.1 audio low volume
By DunnoNo in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2017, 12:17 -
Panasonic HC V720- no sound when external mic is plugged in
By g_knoll in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Apr 2017, 07:25
