So I kind of Frankensteined together an old dell case with a E3-1230 CPU. I don't think it supports audio but that's not a big deal cause I have a 1060 GTX that had handled the sound through HDMI. Now I'm thinking about adding a sound bar that does bluetooth. Am I going to run into issues if I get a USB bluetooth transmitter to send the sound to the sound bar? Thanks in advance for any help!
Any computer in the last 20 years supported audio cards,as to using bluetooth there should be no issues as long as they pair up.
If you are sending video out through HDMI, you will want to explicitly disable the hdmi sound, as it always otherwise takes priority in conjunction with hdmi video.
Other than that, assuming you have well made drivers (no fly-by-nights), you should be fine.
Quality over BT is another matter. Much depends on which protocol you are using (e.g. proprietary user data streaming vs. unidirectional hifi audio streaming vs. bidirectional lo/med fi audio communication), and which codec. And this depends on both source and destination capabilities, since they negotiate.
Use bluetooth speaker as visualiser
By therock003 in forum Newbie / General discussionsReplies: 9Last Post: 13th Aug 2020, 05:42 -
Can you recommend a product to me -- digital media player WITH BLUETOOTH
By True Colors in forum Newbie / General discussionsReplies: 6Last Post: 15th Dec 2018, 00:13 -
Can I add audio Bluetooth to Vizio TV?
By peggypwr1 in forum AudioReplies: 4Last Post: 19th Nov 2018, 02:01 -
Webcam help (Skype+narrowviewangle+wifi-bluetooth )
By ascanio1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 22nd Jan 2018, 16:31 -
A Tale of 4 Bluetooth Dongles
By Seeker47 in forum ComputerReplies: 11Last Post: 21st Apr 2017, 11:34
