I recently picked-up a Panasonic ES-15---hoping that the line TBC will clean-up the glitches in my video captures. But first, I have a couple questions:
What (if any) settings do I need on the ES-15, to take advantage of the line TBC on pass-through?
Do I need to pass the audio through the ES-15 as well (to keep it in sync)? Or, should I still run the audio directly to the capture device?
The line TBC is always on.
Find the NR, turn if "off" (still on, just not as aggressive now)
Black level in menu may need adjusting. I forget offhand which is best setting. You don't want it too light, nor crush.
Yes, on ES15 audio has delay. So route audio into it, back out.
Not on ES10.Want my help? Ask here! (not via PM!)
Set Input to Lighter, Output to Darker. That gives the least banding (posterization).
https://forum.videohelp.com/threads/380285-Where-did-I-go-wrong-What-am-I-missing#post2460874
Then adjust your capture devices proc amp to the correct levels.
correct setting in vidcoder for old high quality setting
By stargatesuite in forum DVD RippingReplies: 9Last Post: 11th Dec 2020, 16:49 -
Looking For A Panasonic TV (audio) Setting
By hech54 in forum DVB / IPTVReplies: 14Last Post: 26th Aug 2020, 10:59 -
need setting
By gta5 in forum Video ConversionReplies: 0Last Post: 12th Jun 2020, 09:26 -
Software to trim AVCHD MP4 files from a Panasonic Panasonic DMC-TZ70
By Vladimir81 in forum EditingReplies: 2Last Post: 29th Aug 2017, 04:15 -
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 08:30
