Hello! I have a question. As you can see in the picture, Aegisub shows in the left window (circled in red) that the frame 153307 begins at 1:46:34.190, while in the right window (also circled) it's 1:46:34.16. The same situation is with the ending (1:46:40.196 against 1:46:40.21). The question is simple: where is the time shown correctly?
[Attachment 58262 - Click to enlarge]
It may be the actual frame location, or offset for minimum spacing. I switched to Subtitle Edit.
If yer going with the flow, yer going down hill.
How to add the same tags to multiple lines at the same time?
By Malls Baloney in forum SubtitleReplies: 0Last Post: 23rd Sep 2020, 03:57 -
Position tags in Masaf Background Automation in Aegisub
By tamarinera in forum SubtitleReplies: 2Last Post: 26th Jul 2020, 04:17 -
Is converting VSFilterMod tags to mainstream tags possible?
By zerxes96 in forum SubtitleReplies: 0Last Post: 29th Apr 2020, 20:39 -
Aegisub - Is it possible to create a fixed width black box in Aegisub
By netmask56 in forum SubtitleReplies: 7Last Post: 17th Nov 2019, 14:50 -
Moving potplayer always shows message: frame capturing saving to clipboard.
By bobolinkeuphoric in forum Software PlayingReplies: 0Last Post: 31st Aug 2019, 15:58
