When I was trying to clips from a video that I was editing on Virtualdub2, I realized that I only use one or two codecs at a time and I have no idea about the other ones. I have two questions:
- What do some of these codecs for Virtualdub2 do?
- Are they good codecs for editing vdeos in general?
- And what do they do?
[Attachment 58213 - Click to enlarge]
They compress video.
The lossless codecs do not compress by much. But the are generally fast -- reading and writing. They're good for intermediate files -- files you will be editing further, later.
Next are the near lossless codecs, ProRes and CineForm. These compress more than the lossless codecs. But they are visually lossless in many (most?) instances. These are often used as editing intermediates as well.
Then there are the high compression lossy codecs. In order of increasing compression (meaning more compression at similar quality, or better quality at the same amount of compression):
Xvid
VP8, x264
VP9, x265
These are good for your final product (assuming they meat your player requirements).
Finally there are a bunch of legacy codecs which are of no use anymore. Cinepak, Intel IYUV, Microsoft RLE, Microsoft Video 1.
See #1
See #1 -
Like Jagabo said, they are all for compressing the video.
They are all for compressing the video, but some are for playback on specific devices or software. Not all of them will be compatible with all devices and software. A couple of those I have never heard of, but x264 is probably the most compatible on the list next to xvid in my opinion. You shouldn't need xvid unless your wanting to watch your video on ancient hardware/software.
If you want very good quality at an average file size, I would recommend x264
If you want good or average quality at a smaller file size, I would recommend x265
If file size is of no concern, and you just want quality, then I would recommend x264 with a very high bitrate of 16,000 - 30,000kbps for HD, and 2500kbps - 3500kbps for SD. That or lossless x265/uncompressed. Lossless will be a VERY large file size though, and is probably not worth it.Last edited by killerteengohan; 3rd Apr 2021 at 02:00.
One uses 8 bits per channel, the other 10. Support for 10 bit h.264 isn't very wide. For example, if you have a TV with a built in media player that supports h.264 MP4 files it probably will only play 8bit. I would avoid 10 bit h.264 encoding.
What about them? I already gave you a list of increasing ability to compress video. And generally, encoding speed decreases with amount of compression. For example, x265 takes much longer than x264. Pick the one that's fast enough for you and is supported by your playback software and hardware. If you don't know what you're doing -- stick with x264 (8 bit) and x265 (8 or 10 bit).
What codecs are good animated videos?
By Guernsey in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2020, 18:40 -
Virtualdub2 and FFmpeg: How do I convert this code to Virtualdub2?
By Guernsey in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2020, 04:25 -
Good lossy codecs for 1080i/HD?
By ENunn in forum Capturing and VCRReplies: 7Last Post: 22nd Jun 2020, 02:22 -
Having a problem with VirtualDub2
By Bruce Banner in forum EditingReplies: 9Last Post: 19th Aug 2019, 14:19 -
What codecs work great for Virtualdub2 and Youtube?
By Guernsey in forum EditingReplies: 5Last Post: 25th Nov 2018, 17:16
