[Attachment 58210 - Click to enlarge]
I get this error when ripping/compressing an audio CD file.
When I run "External Compressor Test" it works and this is the command-line: C:\Program Files (x86)\Lame MP3 Encoder\lame.exe -V0 "etmp!)(0(.wav" "etmp!)(0(.mp3"
I'm not sure why %source% and %dest% aren't used and where the "etmp!)(0(.wav" and "etmp!)(0(.mp3" are coming from. I tried different entries into the "Additional command-line options" but those weird file names keep showing up in the command-line.
I reinstalled EAC and Lame and went through the Configuration Wizard but I keep getting this strange error which I never had before (it's been many years since I used this program).
Any ideas? Thanks.
-Shimon
And just to clarify, here is a screenshot of the options page and the results (no error) after the test. The weird text I posted above came from the command-line used in the test. So I assume the "LAME MP3 Encoder" parameter scheme is the issue?
[Attachment 58211 - Click to enlarge]-Shimon -
And I tried changing parameter scheme to "User Defined" and used a command-line sample from this guide: https://wiki.hydrogenaud.io/index.php?title=EAC_Compression_Options#External_compression
But I get that same error.
I've read through that Wiki but I feel like I'm missing something fundamental.
[Attachment 58212 - Click to enlarge]-Shimon -
OK. Figured out the problem. Apparently LAME doesn't like writing to my NAS. I changed the output folder to a local drive and it works.
-Shimon -
Hi shimonmor,
I know this is old, but wanted to thank you for updating it when you found the cause!
I was having the same problem and suspected that may be the cause. However, I was able to circumvent this by mapping my destination folder as a network drive (Z
and using that instead of \\. This worked great!
Thanks,
Jeremy
Audacity 2.30 not working with Lame 3.100 or 3.99.5 error message
By hokkom in forum AudioReplies: 2Last Post: 7th Oct 2018, 15:44 -
EAC inserts empty COMPOSER field in CUE sheets
By Keyser in forum ComputerReplies: 1Last Post: 9th Feb 2018, 06:18 -
Playing 4k HVEC 100% CPU usage & stutters
By Gurd99 in forum Software PlayingReplies: 10Last Post: 15th Jan 2018, 01:15 -
EAC - How to Auto Fill CD TAG Metadata Info for Unlisted CD's
By Jerry22 in forum AudioReplies: 3Last Post: 12th May 2016, 02:00 -
EAC - Does v1.1 Support Local FreeDB Database
By Jerry22 in forum AudioReplies: 0Last Post: 11th May 2016, 16:19
