Why is it when I use eac3to to extract AC3 audio as AC3, and then extract the same AC3 track as FLAC from a Blu-Ray, the volume on the FLAC extraction is much louder? It's not just this Blu-Ray set either, it seems to be when I extract AC3 as FLAC from any Blu-Ray.
It says clipping is detected, and would need a second pass when extracting as FLAC. Does that have anything to with it? I would think that would lower the volume if thats the case in order to stop clipping.
Do the Blu-Rays normalize AC3 audio or something to lower the volume of a much louder source audio when it is put onto the Blu-Ray? Which one is the correct volume?
Code:M2TS, 1 video track, 5 audio tracks, 7 subtitle tracks, 0:23:12, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 2: DTS Master Audio, 5.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 3: AC3, 5.1 channels, 640kbps, 48kHz 4: AC3, 5.1 channels, 640kbps, 48kHz 5: AC3, 5.1 channels, 640kbps, 48kHz 6: AC3, 5.1 channels, 640kbps, 48kHz 7: Subtitle (PGS) 8: Subtitle (PGS) 9: Subtitle (PGS) 10: Subtitle (PGS) 11: Subtitle (PGS) 12: Subtitle (PGS) 13: Subtitle (PGS) [a03] Extracting audio track number 3... [a03] Decoding with libav/ffmpeg... [a03] Reducing depth from 64 to 24 bits... [a03] Encoding FLAC with libFlac... [a03] Creating file "C:\Users\???\Desktop\Encoding\TSM\Episode 1\T3_Audio - English.flac"... [a03] Clipping detected, a 2nd pass will be necessary. <WARNING> [a03] Starting 2nd pass... [a03] Extracting audio track number 3... [a03] Decoding with libav/ffmpeg... [a03] Reducing depth from 64 to 24 bits... [a03] Encoding FLAC with libFlac... [a03] Applying -0.14dB gain... [a03] Creating file "C:\Users\???\Desktop\Encoding\TSM\Episode 1\T3_Audio - English.flac"... Video track 1 contains 33384 frames. eac3to processing took 3 minutes, 57 seconds. Done.
				Results 1 to 1 of 1
  Alternative to eac3to for Linux?By nickiman in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2019, 05:03
  Eac3toBy gartzo in forum AudioReplies: 3Last Post: 17th May 2018, 09:18
  Popcorn and eac3toBy marinewonder in forum Video ConversionReplies: 2Last Post: 26th Dec 2017, 06:04
  EAC3To Incorrect Slowdown? EAC3To Broke?By TheLastOfThem in forum AudioReplies: 44Last Post: 13th Jul 2017, 21:42
  Aac eac3toBy TheLastOfThem in forum AudioReplies: 7Last Post: 8th Jul 2016, 16:59
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
