Is there anything that adjusts levels on flac files on the fly?
At the moment I use Abode Audition but that means re-encoding. Not that it matters but is a step more than perhaps needed.
I've Googled and seen mention of "normalisation" but I don't think that's what I want. Isn't that some sort of control to make soft passages loud etc? Ideally I just want to + or - by a db amount.
or maybe you are referring to dynamic range compression?
Foobar Flac Volume
By kirkmc in forum AudioReplies: 5Last Post: 7th Jan 2021, 21:51 -
FLAC v1.3.3 with almost 1MB ?
By Gradius2 in forum AudioReplies: 1Last Post: 23rd Aug 2019, 10:52 -
Is FLAC exactly the same than LPCM?
By Enrik in forum AudioReplies: 17Last Post: 17th Jul 2019, 15:01 -
Flac-Mp3
By kirkmc in forum AudioReplies: 2Last Post: 6th Nov 2018, 15:26 -
24 Bits 5.1 FLAC Lower kHz than 16 Bits Stereo FLAC?
By draig-llofrudd in forum AudioReplies: 5Last Post: 17th Dec 2016, 08:03
