Results 31 to 36 of 36
I've never come across uncompressed being required, neither hobby or pro settings.
Uncompresses has too much resource overhead (I/O).
FFV1 is also not good for capture, lots of incompatibilities.Want my help? Ask here! (not via PM!)
I'm having decent luck using Huffyuv, but I can't view this lossless avi file in Vegas Pro. When I captured uncompressed I could drop that file in timeline. It's ok because I'm deinterlacing and upscaling with AVISynth and Vegas recognizes that new avi. One problem is I won't know if the audio and video are out of sync until I do the conversion.
I'm currently having loss signal issues (but no dropped frames) with my vhs captures. I'm looking for an external full-frame TBC. You have a great section on this over at Digital FAQ. Didn't realize these things were going for that much $. I do have a Toshiba dvd recorder I bought for it's 3d comb filter. Going to test that next. I also have an Analog Devices EVAL 7842 board that has TBC; just not sure yet if it's line-based or full frame. -
To view the raw capture file I've been opening VirtualDub and dropping the file in. Is there a different way to view?
But with this method I can't tell if the video & audio are the same length. When I open files in Vegas I can see the length of each track (video & audio) and I was having sync issues where the audio was about 15 frames longer than video. I adjusted a few settings in VirtualDub after viewing Lordsmurf's suggestions at Digital FAQ and solved that issue.. -
Note that audio and video don't have to be the same length. Often one of the other starts and/or ends seconds before or after the other. You only care if they are synchronized. Just play the script in VirtualDub to see if the audio and video are in sync.
VirtualDub: "AVI Import Filter error: (Unknown) 80040154"
By Xavier in forum Newbie / General discussionsReplies: 11Last Post: 15th Dec 2021, 18:49 -
Anyone have insight into what kind of "Uncompressed AVI" Swivel outputs?
By Asterra in forum Video ConversionReplies: 2Last Post: 15th Apr 2019, 08:44 -
batch that verify if a VFW codec is installed and "usable" by Windows?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2018, 23:27 -
VirtualDub's "Codec-friendly sizing" what is it for?
By synnchan in forum Newbie / General discussionsReplies: 3Last Post: 24th Oct 2017, 13:56 -
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jul 2016, 22:39
