I does seem that VDub disables the procamp settings when capture is initiated. I have no clue why it does this. In fact, during an active capture, the levels and capture pin menu items are grayed-out! I know that others have worked with VDub. How did you get around this? I have seen GraphStudio mentioned. How is this used, and integrated into the workflow?
Results 31 to 40 of 40
It's not VirtualDub's fault. It's the driver.
Use GraphStudio. Once open, add the capture or crossbar filter (whichever has the proc amp), right click on it and select Properties. You can adjust the proc amp while VirtualDub (or some other program) is capturing. -
OK, I am trying to understand how to use GraphStudio. I am really just guessing here. I assume that I first select an input (in this case, the Hauppauge USB). I then select a filter (in this case, the procamp). I am guessing that then, I somehow pass the output from GS to Vdub, and use VDub's histogram to monitor my procamp adjustments. Or, am I totally off-base. I really need some step-by-step help with this one.
Proceed as follows:
1) Plug in the Hauppauge USB to your PC
2) Open GraphStudio
3) Menu Graph -> Insert Filter: The 'Filters' Window will pop up, listing all the filters
4) In this Filters Window scroll down to the 'Hauppauge Cx23100 Video Capture' (or whatever similar you have), double-click or press 'Insert': This will insert the Cx23100 box in the Graph editor
5) Right click on that Cx23100 box and select 'Properties....': In the opening Hauppauge Window select the Tab 'Video-Proc-Amplifier'
6) Open your capturing SW (Vdub, or whatever you are using)
7) After starting the capturing, the proc amp setting may be reset, but now you can adjust these again in GraphStudio as you prefer. -
Thanks. That works. Yes, the procamp settings do reset once capture start/stops. Any way to keep it from doing this? Or, should I just start capture and adjust the settings, before I start the tape? Any way to save my settings in GraphStudio?
Also, I noticed options for "Intelligent Connect", "Direct Connect", and "Media Type Connect". Do I need to select one of those? Or, do those only apply if I am using the node system? -
Not as I know. It's a driver issue.
Yes, or start the tape and make the adjustments anytime on the fly during capturing. Just keep GraphStudio running.Or, should I just start capture and adjust the settings, before I start the tape?
You can save but you will probably have to click on the proc-amp sliders again after every capture stop/restart.Any way to save my settings in GraphStudio? -
^ I agree 100% with all of Sharc's points in post #36, based on my own experience doing this since 2013 with multiple capture cards.
https://forum.videohelp.com/threads/360129-How-to-use-Avisynth-videoscopes-with-realti...Dub-ffdshow%29My YouTube channel with little clips: vhs-decode, comparing TBC, etc. -
It might be possible to set the driver defaults in the Registry. If it saves them there and you can find where. An even more unlikely possibility is to edit the driver with a hex editor and change the values stored there.
I have heard about default values being set in the registry. Has anyone ever done this? I suspect that such numbers would be arcane signal-level values, used as reference by the A/D converter. But, that is just a guess. Some graphics-card drivers (like nVidia) have their own built-in software, to change default values. I'm surprised that a reputable company like Hauppauge would not have a similar feature in its drivers---especially since the default contrast is set so high. I don't suppose that such drivers could be calibrated with an ICC profile, like a monitor or printer?
Like all the other consumer video companies, there's nobody left a Hauppauge that knows anything about video. They buy reference hardware and software, and put their name on it.
You're right, the values stored in the Registry may not be the same as the values you see in the driver's proc amp. You just have to experiment to see what the values give you.
USB2 HDMI Video Capture - Sony HD Video Cam to PC transfer
By pchan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 27th Feb 2019, 21:16 -
I-O Data GV-USB2 NTSC Capture Test
By SameSelf in forum Capturing and VCRReplies: 17Last Post: 10th Oct 2017, 18:34 -
verical 4px black bars in video captured with a usb capture stick
By codemaster in forum Capturing and VCRReplies: 1Last Post: 22nd Jun 2017, 22:24 -
H.265, will it go mainstream or stick to H.264?
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 19th Jan 2017, 01:59 -
Roku stick???
By Davegorwill in forum Newbie / General discussionsReplies: 3Last Post: 9th Dec 2016, 14:12
