I have several DVD's with audio in either the LEFT or RIGHT channels. One of my biggest pet peeves are people who can't figure out how to hook up BOTH audio channels on a DVD recorder! Ideally I'd like to find software that could change the audio of VOB files directly and save them maintaining the DVD structure without re-authoring. I tried OJOsoft's Total Video Converter which allows you to change the audio to MONO and re-save the VOB, however I was only able to try the trial version which only saves 30 seconds of a file and their website purchase links are broken.
Any alternatives?
Thanks!
PRTV
Wouldn't be easier just to set your receiver to output mono sound in both speakers?
You can use ffmpeg to reencode the one good channel to a single mono channel:
https://trac.ffmpeg.org/wiki/AudioChannelManipulationCode:ffmpeg -i input.ext -map_channel 0.1.0 -c:v copy -c:a mp3 -b:a 128k "output.ext"
Combine left and right channel audio in MP4
By stevet in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2023, 11:35 -
Audio only coming out of left side in video on VSDC. How do I fix this?
By apollog in forum Newbie / General discussionsReplies: 0Last Post: 15th Dec 2019, 09:25 -
How to fix audio that jump from channel to channel?
By midts in forum AudioReplies: 2Last Post: 24th Apr 2017, 07:04 -
5.1 AC3 audio.. no sound from left channel in VLC or mpv, fine in Audacity
By arcooke in forum AudioReplies: 1Last Post: 26th Dec 2016, 02:53 -
Ripping Multi Channel DVD Audio
By phantomengineer in forum AudioReplies: 15Last Post: 16th Oct 2016, 20:12
