Page 2 of 2
FirstFirst 1 2
Results 31 to 47 of 47
  1. It's my opinions that that noise is on the original film, so it should remain in the video. If you really want to remove it you can use a filter that includes spacial noise reduction as well as temporal noise reduction. Try something like MCTemporalDenoise(settings="very high") instead.
    Also, I just noticed the video needs a little more cropping at the top and right of the frame.
    Apr 2012
    Portugal
    Replacing Temporaldegrain by MCtemporaldenoise ?
  3. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    As alternative, if you are more familiar with TemporalDegrain2 you can use its post-processing.
    From its doc:
    # recommendation:
    # 3. if more denoising is needed try postFFT=1 with postSigma=1 and postDither=-1, then tune postSigma (obvious blocking and banding of regions in the sky are indications of a value which is at least a factor 2 too high)
    # 4. if you would need a postSigma of more than 2, try first to increase degrainTR. The goal is to balance postSigma and degrainTR. However, do not increase degrainTR above 1/8th of the fps (at 24fps up to 3).
    # 5. if there are any issues with banding switch to postFFT=3
    # - postFFT, if you want to remove absolutely all remaining noise suggestion is to use 3 (dfttest) for its quality or 1 (ff3dfilter) is much faster but can introduce banding. 2 and 4 are GPU based versions.
    # - postSigma, increase it to remove all the remaining noise you want removed, but do not increase too much since unnecessary high values have severe negative impact on either banding and/or sharpness
    # - postDither, positive values are used as parameter for dfttest (values above 2 can remove preexinsting banding), negative values indicate 16 bits FFT processing (to be used only with postFFT=1 or in case of strong paranoia regarding banding)
    Apr 2012
    Portugal
    Yes.
    I installed the filters asked by MCtemporalDenoise but i have this message?
    Do you have an idea what i am doing wrong?
    LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\LSMASHSource.dll")
    Import("C:\Program Files (x86)\AviSynth+\plugins\Stab.avsi")
    Import("C:\Program Files (x86)\AviSynth+\plugins\srestore v2.796.avs")
    Import("C:\Program Files (x86)\AviSynth+\plugins\TemporalDegrain.avs")
    LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\DePan.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\DePanEstimate.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\mvtools2.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\RgTools.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\fft3dfilter.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\aWarpsharpMT.dll")
    LWLibavVideoSource("C:\Users\David GC\Desktop\Capt Tsubasa sample.mkv")
    Crop(14,4,-10,-4)
    ConvertToRGB(interlaced=true, matrix="rec601").RGBAdjust(r=251.0/281.0, g=251.0/281.0, b=251.0/221.0).ConvertToYV12(interlaced=true, matrix="rec709")
    QTGMC(sharpness=0.6)
    Stab(range=4, dxmax=4, dymax=4, mirror=15)
    SRestore()
    dehalo_alpha(rx=2.5, ry=2.5)
    Hysteria(strength=2.0)
    MergeChroma(aWarpSharp2(depth=3), aWarpSharp2(depth=15))
    nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=1024, fheight=768)
    Sharpen(0.2)
    nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=1440, fheight=1080)
    Sharpen(0.2)
Name:	Capt TsubasaTEST000000.bmp
  5. Here's the version of Gradfun I have:
    Apr 2012
    Portugal
    It's the one that I have also.
    It's weird, all the .avsi files gives me that error now.
    MCTemporaldenoise, also.
    I made something wrong.
  7. The error message doesn't make sense. The first 135 lines of that avsi file are comments. So there can't be an error on line 3. Did you check the contents? Don't just rely on the name.
  8. Try mctemporaldenoise with the gradfun2db turned off, and not being used by making GFthr=1.00 instead of its default which will deband the video, and destroy more detail.
    mctemporaldenoise(sigma=2, sharp=false, radius=1, ecrad=1, AGstr=0.5, GFthr=1.00) # Increase sigma to 3-6 to get stronger denoise if you want
    It might get it working, but you should still try to fix the underlying issue.
    Apr 2012
    Portugal
    You're right. The content was different.
    All OK.
    I will try the encode with MCTemporalDenoise.
    Thanks !
    Apr 2012
    Portugal
    Originally Posted by killerteengohan View Post
    Try mctemporaldenoise with the gradfun2db turned off, and not being used by making GFthr=1.00 instead of its default which will deband the video.
    Will try it too.
    Thanks.
    Apr 2012
    Portugal
    The result is good!
    Apr 2012
    Portugal
    It seems to have more noise that Jagabo's script ?
    i tried with sigma 6.
  13. The "very high" preset uses a sigma value of 16.
  14. Originally Posted by jagabo View Post
    Yeah, like Jagabo said, it uses a much higher sigma which is very destructive to details and will smudge out grainy artifacts more to look cleaner. It will look cleaner, but you are wiping out detail. If you want smeared out garbage to get it cleaner looking, then by all means, raise the sigma higher and use DNR that's overkill. It's your call. I just typically try never to go above 6, and even then I feel 6 is too strong.
  15. Originally Posted by david.dgc View Post
    If I want a 960x720 output which and where do you think that the resizer shoud be put on the script?
    Try this:
    Crop(240, 0, -240, -0)
    Spline36Resize(960,720)
    ConvertToRGB(matrix="rec709")
    RGBAdjust(rb=-29, gb=-26, bb=-27)#, r=250.0/200.0, g=250.0/182.0, b=250.0/154.0)
    RGBAdjust(r=250.0/200.0, g=250.0/182.0, b=250.0/154.0)
    ConvertToYV12(matrix="rec709")
    Stab(range=4, dxmax=6, dymax=6, mirror=15)
    TemporalDegrain(sigma=4)
    QTGMC(InputType=2)
    MergeChroma(aWarpSharp2(depth=10), aWarpSharp2(depth=20))
    Sharpen(0.3, 0.2)
    I toned down the sharpening and reduced the Stab limits to better suit the smaller frame size.
    I used your script and the result is great !
    I will try now some full episodes.
    Thanks !!
    hey dear brother can you please help me out to set all of these script for staxrip please
    Sent from my M2101K7BI using Tapatalk
  16. Originally Posted by imsrk48 View Post
    I don't know much about staxrip.
