Hello,
I am wondering how I would find out which frame in a video belongs to which audio sample. I was thinking about using ffmpeg. I want to use the information contained in the container to find the solution. In the end I would like to automate the process with C++ but for the beginning I am happy with ffmpeg used by command line.
Lets say: I know audio sample 39822 has the characteristic I am looking for. Using the information contained in the container, I want to find out to which frame the audio sample was recorded. (Key frames/ Samples?)
I was thinking ffmpeg could help me with this problem.
I tried to find the answer within the ffmpeg documentation but did not succeed.
Maybe you guys can give me a hint which tool (maybe even other than ffmpeg) to use or where to look specific.
Thanks in advance Tim
Results 1 to 9 of 9
they are totally independent. you match them by the common time.
scott -
Example:
audio sample 328165
@ 48kHz samplerate, this is 328165 / 48000 = 6.8367sec
video @ 25FPS (since you're in Deutschland and the math is easier)
25 * 6.8367 = Frame 170.91927, but since there is no such thing as a partial frame, it's just frame 170. Almost 171.
Scott -
You can use the timestamps for the video and audio chunks. But once again, there isn't a1:1 relationship between video chunks and audio chunks.
At the best of my knowledge this depends on how the container wraps and indexes the video and audio chunks, e.g. MXF Frame wrapped means to have a guaranteed relation between audio and video chunks in the existing Index. Despite it is about chunks, which can also be called frames - instead of "Samples". (where again each frame/edit unit of course consists of a defined number of samples because we deal with fixed frame rate).
So in my head, it depends on the container if such a releation is given or needs to be recreated by the decoder (e.g. re-indexing ).
The question itself about Samples is a little confusing here because it implies that this is about uncompressed audio. Is this given?
Might be better @tim5 if you add some words about the container you are working with?Last edited by emcodem; 1st Apr 2021 at 03:25.
Authoring Blu-Ray Audio with different sample rates and bonus video.
By SF01 in forum Authoring (Blu-ray)Replies: 7Last Post: 26th Jun 2020, 13:27 -
Find out frame numbers for qp files
By Valit in forum Newbie / General discussionsReplies: 7Last Post: 13th Feb 2020, 13:57 -
VBR: Find out absolute data position of individual frame/sample/time.
By TechLord in forum Newbie / General discussionsReplies: 19Last Post: 27th Feb 2018, 01:13 -
Where to Find Test/Sample MP4 Video Loop to Test Webcam?
By pone44 in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2017, 19:50 -
How to find the audio track in this video ?
By munununu in forum Newbie / General discussionsReplies: 3Last Post: 26th Jun 2016, 13:21
