VCDhelp posts have been very helpful in getting SVCD to play on the RV-31. Now I would like to reduce the bitrate (to say something like 1800) to fit 45 minutes or so on one CDR. When I try the multiplex trick and then used TMPGEnc tricks described elsewhere on vcdhelp to lower the bitrate of the resulting (non-standard) MPEG-1 VCD, I seem to get audio play but no video play on the Panasonic after burn with Nero. (The resulting disc plays fine in WinDVD.) Any ideas about how to successfully do bitrate reduction would be most appreciated. For instance, would it help to do the bitrate reduction first, as non-standard SVCD, and THEN do the multiplex??
Results 1 to 1 of 1
AVCHD from panasonic lumix, which software is compatible?
By rocketman778 in forum EditingReplies: 0Last Post: 25th Nov 2011, 16:53 -
How Create ACHD side by side compatible with Panasonic 3D Cam and HDTV?
By castana in forum Video ConversionReplies: 7Last Post: 25th Jul 2011, 16:47 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
MKV H264 bitrate reduction (also DTS to AC3)
By Tooncis in forum Video ConversionReplies: 0Last Post: 2nd Jun 2008, 09:33 -
Panasonic DVD recorders AV-in NR (noise reduction)
By JoseD in forum RestorationReplies: 2Last Post: 5th Jan 2008, 00:04
