I tried this recently and was surprised that the result was less quality than the bluray disc it was ripped from...is that normal?
Results 1 to 10 of 10
It was a bluray rip from yify, looked great streaming but when I converted to bluray didc looks like it lost resolution from winavi software
Unless the file you downloaded was the same size or larger than a full bluray disc, yes, it's normal. If the resolution and play time are the same and the file is smaller, something had to have been taken out. Quality.
Most of the yify BD rips I've seen are less that 2 GB. You really expect a 30+ GB Blu-ray video compressed to 2 GB, then (probably reencoded again by winavi) to look like the original BD? Buy the BD if you want BD quality.
Thanks for the info, I will keep the mp4's as they are, they doook great on my 65 inch Vizio as is without burning back to bluray
Rip Bluray Untouched "1920x1080" to 1080p - 720p ecc.
By humambrose in forum Blu-ray RippingReplies: 2Last Post: 23rd Dec 2020, 14:55 -
1080p 25fps Bluray
By max_cady in forum Newbie / General discussionsReplies: 5Last Post: 10th Dec 2020, 12:17 -
Best Way To Downscale 1080p 30fps Sports Video to 720p for Bluray?
By AndersonJames in forum RestorationReplies: 10Last Post: 18th Jun 2020, 13:25 -
How do I downscale a 4K video to 1080p Bluray quality?
By SomeoneNeutral in forum Authoring (Blu-ray)Replies: 3Last Post: 18th Sep 2019, 18:13 -
Mass convert multi 1080p BluRay REMUX AVC to multi 1080p hdlight
By levi59 in forum Newbie / General discussionsReplies: 5Last Post: 17th Dec 2017, 16:43
