I used the convert guide on this site, followed it exactly. The DivX file was 697 Mb, lasting roughly 1 hour 29 minutes. After converting it to MPEG2 using the guide. It was 1.7 GB's big. Is this normal? Do i have to use 3 CD's ? I converted it to SVCD, because that's what the fps asked for. Please advice.
So it goes. I too have followed the many and various guides with mixed results. Mostly the finished products are quite watchable 2 disk VCDs which I play on a Brand X DVD player which plays almost all formats.
I keep reading that SVCD on 2 disk is easy. Prolly is but I' too lazy to dig deeper.
Abit KT7
Athlon 1100
512MB Crucial
Yamaha CRW8424S SCSI
Pioneer DVD 305 SCSI
Maxtor 4D040H2
Quantum LM30
WDC WD300BB
Cable -
im not an xpert , however i have followed the guides , i have gotten good results , in response to your question yeah the file size is normal for an mpg2 conversion if you need to calculate the file size use a bit rate calculator , undr the tools section
DVD (MPEG2) or DivX
By MI6 in forum Video ConversionReplies: 1Last Post: 20th Sep 2010, 14:51 -
vob/mpeg2 to Divx close to Dr Divx?
By Tiribulus in forum Video ConversionReplies: 8Last Post: 5th Dec 2009, 12:52 -
divx to mpeg2 with winff = error
By tors10 in forum Video ConversionReplies: 2Last Post: 12th Dec 2008, 15:58 -
Better format to encode to: MPEG2 or DivX/AVI?
By Grunberg in forum Video ConversionReplies: 15Last Post: 15th Feb 2008, 09:29 -
DivX and MPEG2 capture devices
By Arcturus in forum Capturing and VCRReplies: 18Last Post: 25th Aug 2007, 00:49
