Hi guys and thanks for your time.
Do i need to convert all Mp4 into MPEG in order to edit? If so can i do this inside Premier 2020?
Ive tried for a couple of times on and off and im clearly missing something. I should point out ive never done video editing ever before but would like to be able to do basic editing to familiarise myself with what's needed. Im familiar with Photoshop.
ISSUES:
In Windows Photos/Movie maker it plays but with no picture.
In Premier it plays with sound but video is jerky.
In VLC it plays perfectly.
In camera it plays perfectly.
Im amazed that it doesn't simply play in everything.
I tried adjusting the buffer allocation in premier but it made no difference. All ive done is load the file and play it back, I've not even started editing it yet lol.
COMPUTER INFO:
Intel i3 1.40Ghz, 8GB Ram
FILE INFO:
General
Complete name : C:\Users\user1\Desktop\NEW Personal Data 2020\Phone camera\Chloe Majic\Chloe Majic Coin 2.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42)
File size : 5.98 MiB
Duration : 2 s 754 ms
Overall bit rate : 18.2 Mb/s
Encoded date : UTC 2020-10-02 16:21:48
Tagged date : UTC 2020-10-02 16:21:48
com.android.version : 7.0
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Codec ID : avc1
Source duration : 2 s 788 ms
Bit rate : 16.7 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 24.745 FPS
Minimum frame rate : 13.377 FPS
Maximum frame rate : 25.245 FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.325
Stream size : 5.47 MiB (92%)
Source stream size : 5.55 MiB (93%)
Title : VideoHandle
Language : English
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
transfer_characteristics_Original : BT.601
Matrix coefficients : BT.709
mdhd_Duration : 2754
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration : 2 s 709 ms
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 42.7 KiB (1%)
Title : SoundHandle
Language : English
