Results 1 to 10 of 10
    Mar 2021
    Kingston upon Hull, England
    Hi, When I download movies or TV programmes and transfer them to USB to play on my TV I cannot play them in the 16:9 ratio. But I can on my PC. I cannot change the TV picture size when playing files on USB. The files I download are 16:9 ratio because I can play them in that ratio on my PC through the USB. Please help.
  2. Member DB83's Avatar
    Jul 2007
    Install a small program called mediainfo and post a text mode report of one of the files that does not display correctly on the tv
    Mar 2021
    I'm not sure how to do that but here is one of the files info. This plays in 16:9 on USB when plugged into PC but when plugged in to TV only plays in 5:4.
    https://www.ettvcentral.com/torrent/1146217/formula-1-2021x01-bahrain-qualifying-skyf1hd-sd
  4. Member DB83's Avatar
    Jul 2007
    I am not going to download that. The program is easy enough to use - load the video, select the view menu and then text mode
    But if this displays as 5:4 it suggests that you have a 720*576 video with a 16:9 flag that only a PC player will support if there is no player setting on the tv player to force the aspect ratio. The program would confirm the assumption.
    Mar 2021
    these are the details of one of the video's
    Video
    Format : AVC
    Format profile : Main@L3.1
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 4 frames
    Codec ID : avc1
    Duration : 55 min 20 s
    Bit rate : 1 353 kb/s
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 FPS
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Bit rate mode : Constant
    Bit rate : 160 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Category: TV > Sport
    Lang: English English
    Total Size: 1.80 GB
    Info Hash: 5d8b7e75d236b5800f1a10e77800b41a28b4f831
    Added By: smcgill1969
    Mar 2021
    Which width and hight do I need for it to play 16:9 or 16:10 on my TV please
  7. Member DB83's Avatar
    Jul 2007
    The video confirms my assumption.
    If it displayed correctly, the video would be 1024*576. But do check all your tv settings for the usb first
  8. Load your video in clever Ffmpeg-GUI, select multiplex, click on target file, accept the proposed filename, set DAR to 16:9, click multiplex, done.
    The new created video should play fine on your TV.
  9. There are no surprises here. The media player built into many TVs do not respond to DAR/SAR flags. You have to resize the video to match the DAR (in this case, 1024x576, or some other 16:9 frame size) and reencode.
  10. I have found that many TV's do not respond to the DAR flag at stream level, but do respond at container level.
