  1. Hello
    I stumbled upon this stream that I cannot capture. (use ublock origin before visiting the site)
    http://freestreams-live1.com/sportklub-3sr/
    Can anybody figure it out?
    It seems m3u8 changes after ~20 chunks.
    Even if I manually download the chunks, I can't combine them, mediainfo doesn't show anything for them. Do I need an init file?
  2. hi! did you try ffmpeg ?
    ffmpeg -headers "referer: https://www.wmsxx.com/cdn.php?live=wiz9&vw=100vw&vh=100vh" -i "https://y.wmsxx.com:30443/live/wiz9/playlist.m3u8?wmsAuthSign=c2VydmVyX3RpbWU9My8yNi8yMDIxIDE6NTM6MzkgUE0maGFzaF92YWx1ZT1NZk13QnkzOWtXK2dFNGlZWHFGREhBPT0mdmFsaWRtaW51dGVzPTEyMA==" "output.ts"
    download link: https://gofile.io/d/uDZCOf (30 min 24 s)
    General
    Complete name                            :
    Format                                   : MPEG-TS
    File size                                : 252 MiB
    Duration                                 : 30 min 24 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 1 158 kb/s
    Video
    Menu ID                                  : 1 (0x1)
    Format                                   : MPEG Video
    Commercial name                          : HDV 720p
    Format version                           : Version 2
    Format profile                           : Main@High 1440
    Format settings, BVOP                    : No
    Format settings, Matrix                  : Default
    Format settings, GOP                     : N=12
    Codec ID                                 : 2
    Bit rate mode                            : Variable
    Bit rate                                 : 939 kb/s
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Frame rate                               : 30.000 FPS
    Bits/(Pixel*Frame)                       : 0.034
    Time code of first frame                 : 00:00:00:00
    Time code source                         : Group of pictures header
    GOP, Open/Closed                         : Open
    GOP, Open/Closed of first frame          : Closed
    Stream size                              : 204 MiB (81%)
    Audio
    Menu ID                                  : 1 (0x1)
    Format                                   : MPEG Audio
    Format profile                           : Layer 2
    Codec ID                                 : 4
    Bit rate mode                            : Constant
    Bit rate                                 : 160 kb/s
    Sampling rate                            : 22.05 kHz
    Frame rate                               : 19.141 FPS (1152 SPF)
    Delay relative to video                  : -88 ms
    Stream size                              : 34.8 MiB (14%)
    Menu
    Menu ID                                  : 1 (0x1)
    List                                     : 256 (0x100) (MPEG Video) / 257 (0x101) (MPEG Audio)
    Service name                             : Service01
    Service provider                         : FFmpeg
    Service type                             : digital television
    discord=notaghost9997
  3. Originally Posted by notaghost View Post
    Thank you kind sir, it worked!
    However, the quality is not the same as the stream.
    Can I somehow get it with better bitrate?
