Results 1 to 18 of 18
    Dec 2020
    Malaysia
    not sure what am doing wrong. can't get keys
    anyone please help thanksImage
    [Attachment 58029 - Click to enlarge]
    site : monomax.me
  2. Originally Posted by joedecruz View Post
    site : monomax.me
    use an older chrome version, ~81 from early 2020
    Dec 2020
    Malaysia
    thanks. anywhere recommend to download old chrome?
    Dec 2020
    Malaysia
    thank you . downloaded old chrome. worked fine. thanks again
  5. or you can just replace file 'widevinecdm.dll' and 'widevinecdm.dll.sig' with older version
  6. Originally Posted by tamagoyaki View Post
    Hmm, I just did this and videos won't load
  7. can you try this? https://gofile.io/d/t6qwBQ
    at least it works for me on bitmovin.com
  8. Originally Posted by tamagoyaki View Post
    Yep, these worked. Thank you!
  9. mine vod using shaka player does not show key at all, other works just fine any ideas why?
  10. Originally Posted by tamagoyaki View Post
    After a few days, extension stopped working.
    I then installed old Chrome version 83 on a virtual machine and grabbed the files from there.
    Replaced them on my host where I have latest Chrome version.
    Still didn't work.
    Then I found out that Chrome puts these files on another location besides
    C:\Program Files (x86)\Google\Chrome\Application\89.0.4389.90\Widev ineCdm\_platform_specific\win_x64\
    that location is
    C:\Users\x\AppData\Local\Google\Chrome\User Data\WidevineCdm\4.10.2209.0\_platform_specific\wi n_x64\
    so I also replaced files in this location, and now it works.
  11. Originally Posted by [ss]vegeta View Post
    Still didn't work.
    that location is
    You don't have to install old version of Chrome. You can find and download standalone offline installer, then extract using 7zip. From there you're desired files can be obtained. My case I downloaded Chrome 86
  12. Originally Posted by mmshasan View Post
    Extracting with 7-zip gives me a checksum error and just extracts one file without extension or poper name 102~
  13. Originally Posted by [ss]vegeta View Post
    Check PM
  14. What should I try if I am able to get keys show up in console on some website but not others? Another member was able to extract a working key and send it to me but he prefers not to explain how he did it.
    Anyone else came across different implementations that don’t work with the extension out of the box?
  15. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    Are you sure that the specific site uses widevine? Maybe it's fairplay or playready DRM?
  16. Originally Posted by dabbdubb View Post
    What should I try
    You should try editing one of the extension files to show the key somewhere else instead of the console.
  17. Originally Posted by Sviests View Post
    I am fairly certain that it has to be Widevine because I am playing the video on Windows 10 desktop in Chrome browser. But I admit I am not sure.
    What should I try
    Interesting idea. Maybe the website is suppressing all console output, I’ll check first if I can even console log a normal string on page load.
  18. deleted
