I purchased a new music video recenty and I'm trying to make a backup using MeGUI / Avisynth and XMedia Recode. The source looks HD but the re-encodes all have clearly visible combing effects. I've tried using a de-interlace filter on both with no effect. I'm setting the bit rate at 10,000 and I've tried h.264 and h.265. Part of the problem is that the disk itself is comprised of videos from several different live concerts and some of the songs are a combination of progressive, interlaced and MBAFF.
I'm very much a novice at this and have had good luck in the past with both programs - this disk has me stuck.
Results 1 to 10 of 10
Your explanation doesn't really make sense: MBAFF and PAFF are both techniques to encode interlacing; PAFF encodes the full frame content in interlaced mode regardless of the content, whereas MBAFF encodes areas (in slices of macroblocks) depending on which scan type (progressive or interlaced) returns the more efficient result.
A sample would indeed be important. Deinterlacers only work reliably for native interlacing, where the recording time progresses linearly from one field to the next. But there are also norm conversions with blended fields or even worse mess. -
This is a 15 second clip, untouched from the Blu-Ray:
https://mega.nz/file/Ho5UWCgR#JkU57Bt5XHMzYYBdiSl_Q_Uo2-kiIDE3Jd-2kljvBhc -
Hello again,
I am still having some problems but wanted to wait till the weekend. I uninstalled and reinstalled AviSynth and MeGUI and ran update - just to be sure I had everything current and this is the avs file I am trying to use:
LoadPlugin("C:\Program Files (x86)\MeGUI\tools\lsmash\LSMASHSource.dll")
LWLibavVideoSource("F:\Video\CLIP-2-002.mkv")
tfm().tdecimate()
and the error I get is: There is no function named tfm
I checked and it appears that is part of TIVTC which is in the plugins directory - can you tell me what I need to do? -
Mark/Force MBAFF Encoded Video as Progressive
By ajingo in forum Video ConversionReplies: 7Last Post: 22nd Feb 2021, 06:24 -
Shimmering problem after encoding
By Master Tape in forum RestorationReplies: 63Last Post: 12th Sep 2020, 11:27 -
Encoding Problem
By m00511 in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2018, 08:44 -
Encoding Problem
By m00511 in forum Newbie / General discussionsReplies: 13Last Post: 20th Jul 2018, 09:50 -
Problems Deinterlacing - MBAFF - Separate Fields - Variable Framerate?
By danfgtn in forum Newbie / General discussionsReplies: 4Last Post: 12th May 2018, 19:31
