What is a piece of software called that takes a big video and takes cuts out of it and creates subsequent pieces into file it a certain time interval?
Is there a good one that is free ?
I have several mkv files that I created from vob files and I would like to make them into there smaller files in mkv, preferably with a slider that you put at the intervals. these at minutes: second of the beginning and end?
John
Lossless cuts (no-reencoding) can only happen on keyframes.
If you want a preview + no-overlap frame accurate cut on markers, Avidemux can be used, otherwise mkvtoolnix is a good choice. -
Is there one that has a slider bar that allows you to tell it the begining and end then cut and allows you to paste it into a new project? John
what I am doing is that :
(1) I have a goofy movie that has "how to ride a horse" on it called "Goofy's TV Sports " and is in mp4 format
(2) I would to cut at the end points of "how to ride a horse "
(3) Then paste the cutting in a new window of the program
(4) then rename it form "Goofy's TV sports to "how to ride a Horse"
(5) then save it to mkv
what software can do this
Video cutter/splitter
By alintatoc in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2017, 15:13 -
Video splitter needed
By RBCC in forum EditingReplies: 4Last Post: 12th Mar 2017, 21:51 -
Video Splitter needed
By RBCC in forum EditingReplies: 1Last Post: 11th Mar 2017, 17:34 -
Anyone tried a 4K HDCP with the 1.4 splitter?
By oldfart13 in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2016, 16:34 -
mp4 splitter needed
By RBCC in forum EditingReplies: 4Last Post: 5th Jul 2016, 20:18
