  1. Member jraju's Avatar
    Mar 2013
    India
    Hi,
    I am converting some videos using the same video converer and its settings. On checking the codec in vlc player, it shows the same video , audio codec and same resolution, including the frame rate. But while playling it in vlc media player , the size of the screen differs sizably small compared to other videos converted using the same video converter.
    Why and is there a fix for it.
    how do i find the details in which the size changes while playing
    Mar 2008
    Can you post a sample of the video showing the problem ?
