Hi, until last week (8 days ago) I was downloading every TOTP (Top of the Pops) new episode released on Friday nights using get-iplayer (for macOS) on the highest quality (720p50).
(I'm using the latest versions of all apps and of macOS, so don't need to ask me which versions I'm using)
But "18/10/1990" and "25/10/1990" (dd/mm/yyyy) episodes downloaded yesterday are defective.
I always open the mp4 file on QuickTime Player and check it frame by frame, pausing the video and going frame by frame with the right arrow key on the keyboard to check for issues.
Tried to download the same two episodes using youtube-dl too, I got mixed results:
1) downloading a single mp4 file with youtube-dl using the "--format best" option, it has the same issue as the get-iplayer mp4 file;
2) downloading two individual streams, video and audio (it's the default behaviour), it seems I got a perfect video stream.
Opening the defective video.mp4 file on MKVToolNix, exporting as video.mkv file, then on Terminal doing "mkvextract video.mkv timestamps_v2 0:timestamps.txt", I got a timestamps.txt like this:
# timestamp format v2
0
40
40
60
80
100
120
140
160
200
200
220
240
260
280
300
320
360
360
380
As you can see, there are wrong timestamps:
40 is repeated in two diferent frames (20 is missing),
same for 200 (180 is missing)
etc.
Fixed it creating a new timestamps.txt file:
# timestamp format v1
assume 50.000
Then used MKVToolNix to add the new timestamps.txt file to a new mkv file, then used mkvextract again to check it out, now I got:
0
20
40
60
80
100
120
140
160
180
200
220
240
260
280
300
320
340
360
380
Now everything seems OK.
Then I converted the mkv file to mp4 using Subler for macOS.
Played the new mp4 file on QuickTime Player and played the new mkv file on VLC.
But the issue on playback is still there: the video has some jumps in the motion, it jumps a frame (creating a hole in the motion) and then in the next frame right after the jump it goes back to the jumped frame (where there was the hole).
Downloaded the same "18/10/1990" TOTP episode on the BBC website to play it on the BBC iPlayer Downloads app, it seems fine here, no issue, smooth playing.
Results 1 to 1 of 1
BBC iplayer Downloads
By ghostrewel in forum Video Streaming DownloadingReplies: 8Last Post: 25th Jul 2017, 14:56 -
BBC Iplayer
By Dunmanway in forum ComputerReplies: 1Last Post: 8th Jun 2017, 03:21 -
BBC iplayer help --
By dongy789 in forum Video Streaming DownloadingReplies: 1Last Post: 10th May 2017, 17:01 -
Downloading from BBC iplayer from outside UK
By achy635 in forum Video Streaming DownloadingReplies: 1Last Post: 3rd Dec 2016, 14:18 -
How to download a video from BBC iPlayer
By Joaquim_Link in forum Video Streaming DownloadingReplies: 34Last Post: 28th Mar 2016, 15:07
