Okay, so this is driving me bananas now. Basically, I created a Blu–Ray compatible *.m2ts file, and that file works just fine. I can open it in Finder's "Quick Look" skip ahead, skip backwards, and basically do whatever I want with it while having it behave as expected. If I open the file in VLC, it works as expected there as well. I want to take the video and audio from this file and dump them into an MP4 (or even an MOV) file that open easily in other programs though, without re–encoding anything. To do this I typically use VGTMpeg, which is an FFMpeg variant that has some added capabilities, including the ability to stick linear PCM in an MP4 file. However, no matter what I do, I cannot seek/scrub/fast forward the resulting file, and I have no idea why. Oh sure, I can move the cursor ahead in Finder's "Quick Look," VLC, and in Quicktime, but the video just sort of freeze–frames on the last frame it played and never jumps ahead to where I've moved the cursor. I've tried just sticking the video stream without audio into an MP4 file with the same result, tried adding parameters like -fflags +genpts or -movflags_tmcd on to my stream copy, but nothing has worked so far.
The closest I got was when I tried to use VLC to "rewrap" the video. I told VLC to keep the video (not to re–encode) and did what should theoretically be a stream copy into an *.m4v container, which is what VLC wants to use for the output. This created a video that I could seek/rewind/fast forward from, but it's definitely not a stream copy as it cuts off the ending of the video and has an offset by something like 37ms that differs from the original file. Does anybody know what VLC is doing to make the file searchable though, and if so, how do it in FFMpeg? At the very least, does anyone know how I can spit out a file that I can rewind/fast forward from in FFMpeg without re–encoding? All I want to do is dump the audio and video from the *.m2ts into an mov/mp4 container and be able to skim forward/backward through the video after doing so. Any help would be greatly appreciated!
Specs: Mac Mini (Early 2006): 1.66 GHz Intel Core Duo CPU, 320GB HDD, 2GB DDR2 RAM, Intel GMA 950 integrated graphics card, Matshita UJ-846 Superdrive, Mac OS X 10.5.7 and various peripherals. System runs Final Cut Express 3.5 for editing.
Try mkvtoolnix if MKV is acceptable or perhaps Avidemux, choose the "mp4 muxer" for output format
I tried MKVToolnix but couldn't get the desired result. (Didn't really want an MKV anyway though.) I'll try AviDemux next though. Thank you for the advice!
Specs: Mac Mini (Early 2006): 1.66 GHz Intel Core Duo CPU, 320GB HDD, 2GB DDR2 RAM, Intel GMA 950 integrated graphics card, Matshita UJ-846 Superdrive, Mac OS X 10.5.7 and various peripherals. System runs Final Cut Express 3.5 for editing. -
Okay, so I tried AVIDemux with what I can only describe as "interesting" results. For testing purposes I have my original *.m2ts file with audio and video, as well as an *.mp4 file that exhibits the problems described in the first post. The *.mp4 file has no audio in it (video codec only,) and the *.m2ts has both video and audio.
If I load the *.mp4 file into AVIDemux and try to rewrap it, I continue to get an unseekable/un–fast forward–able file. I can use the MP4 Muxer or MP4v2 Muxer, but the end result is the same; ditto for the MKV Muxer if I output an MKV and convert it back to MP4.
Now if I load up the *.m2ts file, AVIDemux will create an *.idx2 file as soon as it opens the *.m2ts file; interestingly it does not do this for the *.mp4 file. (Does the *.mp4 not require the *.idx2 file?) If I try to output my video from the *.m2ts file into an MKV container and convert it back to MP4, I run into the same problem where I can't seek/fast forward again. However, things get interesting if I try to output an *.mp4 file. First, AVIDemux doesn't allow me to do a video only output from a file with audio, unless you're dumping the video into a raw file, which means that the audio must be converted as AVIDemux isn't capable of handling linear PCM in the MP4 container. (This was fine with me as I figured I would just dump the audio and replace it later if everything worked as expected, which needless to say, it didn't.) I chose AAC (fdk) as my audio codec for testing purposes and "copy" for video. Like VLC, this created a video that I could seek/rewind/fast forward from, but again cut off the ending of the video just like VLC did. To add insult to injury, it also added some obnoxious and ugly macroblocking during a transition near the end of the video. (I checked the *.m2ts file again just to be sure I hadn't somehow missed this before, and can indeed confirm that it's not there; this is a creation of AVIDemux's doing.)
On top of the botched video stream, AVIDemux also made a mess of the audio stream. I have no idea how or why, but for some reason the entire thing has a consistent "buzzing" running through it for the duration of the stream. (The closest analogy I have for this sound would be audio that was recorded from a mic with a damaged cable or a fluorescent light that's on its way out. I'm not sure if it's a 60Hz hum, but it's definitely similar and shouldn't exist given that it wasn't in the source file and nothing else creates this buzzing when converting the audio.) At first I thought that there just might have been a glitch in AVIDemux's implementation of the fdk encoder, so I switched over to "AAC (lib)" and did a second encode. Surprisingly, the second encode resulted in an audio file with the same buzzing problem as well. Oh, and the MKV file where I stream copied the audio and the video? You guessed it, buzzing that wasn't present in the original *.m2ts file was mysteriously added there too, and that was supposedly a stream copy.
Oh, and don't even get me started on trying to get AVIDemux to work in the first place. On one machine the latest stable build compatible with my system refuses to load and constantly crashes on startup. I tried to roll back to an even older version with similar results, before throwing my hands up and going to another Mac with what looks like a slightly older build of the exact same version installed where the app itself was working, despite the weird way it handled my file.
So basically both MKVToolNix and AVIDemux are a no–go, with AVIDemux behaving similarly to VLC. I'm really trying to figure out how AVIDemux and VLC are making the file searchable though as I would like to try and do that through FFMpeg/VGTMpeg, as that seems to be able to avoid mangling the file.
ProWo, the source audio is linear PCM or nonexistent depending on the file I'm working with. I have a way to include it in an *.mp4 container once I get the video to function properly outside of its *.m2ts source file.Specs: Mac Mini (Early 2006): 1.66 GHz Intel Core Duo CPU, 320GB HDD, 2GB DDR2 RAM, Intel GMA 950 integrated graphics card, Matshita UJ-846 Superdrive, Mac OS X 10.5.7 and various peripherals. System runs Final Cut Express 3.5 for editing.
Fast Forward & Rewind
By Killshaak in forum Newbie / General discussionsReplies: 22Last Post: 4th Apr 2021, 13:11 -
Not appear video virtualdub2 fast forward
By media in forum EditingReplies: 2Last Post: 10th Feb 2020, 02:12 -
Grundig 2280 stuck in fast forward
By Arcadian7Litre in forum RestorationReplies: 2Last Post: 11th Aug 2018, 12:28 -
Mitsubishi VCR - Can Only See Picture in Fast Forward or Rewind or Pause
By digicube in forum Capturing and VCRReplies: 2Last Post: 28th Jun 2017, 21:53 -
why won't this disc fast forward?
By DaneClark in forum Authoring (DVD)Replies: 9Last Post: 18th Jun 2017, 19:01
