I recently downloaded VCDeasy and it is not working. It clearly says that my ASPI is wrong or something. Can this be fixed? It says go to settings, but I did, and I don't know exactly what I am supposed to do to correct the problem. If someone out there can help me, please reply.
Peace,
budgirl357
Easy does it
Just download ASPI Layer v4.60 Build 1021 from here:
http://www.whdl16709.pwp.blueyonder.co.uk/download.html
and then you'll be able to enable the CDRDao feature of VCDEasy
Make sure you downloaded the complete VCDEasy package!Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
