Results 1 to 9 of 9
  1. I posted this problem before.
    The problem that I am having is when I attempt to copy a disc with DVDFab. It always copies as far as 51%, then, it will hang there for hours on end. The copying process stops, and sounds as if it is trying to start again, but never does! The same occurs with the latest version of DVDFab. Also, I have cleaned the disc numerous times, and there are no scratches on it.
    How do I get the disc to copy completely?
    Thank you
    Mar 2008
    The drive maybe failing, 51% may be the layer change
  3. Okay, but I can many other discs!
  4. Go through DVD Fab's settiings and set hardware and software retries to 1 or 2. Try ripping again.
  5. How do I get to it?
    Jan 2019
    Europe
    Try MakeMkv
  7. How do I use MAKEMKV to convert the disc into 4.19 GB?
    Jan 2019
    Europe
    You only said you wanted to copy the disc
  9. By converting, I meant copy. Usually, once the file has been copied, it converts to 4.19 GB size, which I can then burn to a 4.75 GB disc.
