  1. Hi,
    I ripped the 2 DVD's of Pearl Harbor with DVD Decrypter.
    Now, I'm loading the VOB files in DVDx, and I'm finding some trouble which I just can't solve.
    Everytime I go to output settings and click the whole button, it's giving me wrong values. Example:
    The first VOB, after loaded, if I use the slider, goes up to 27:58
    When clicking the whole button, it just shows 22:00
    What could be wrong? The same happens if I load all the VOBs (the movie should be (if not wrong) 2:08, but it does only 1:43...
    The main problem is, in case, that I'm not getting the full movie... if I change the values manually, I'm having problem merging (the sound skips)
    any help will be appreciated... thanks in advance
    marcelo_magri
    Athlon XP 1600+
    ECS K7S5A
    256 Mb RAM
    Maxtor 5200rpm 40 Gb HD
    Riva TNT2 32 Mb Videoboard
    Hollywood+ MPEG card
    Toshiba 6x DVD-ROM
    LG 16x10x40 CD-RW
    Apr 2002
    DRAMA
    I use also the Dvd-x.But I thing its better to use the Dvd-x with the Tmpeng encoder.Its very simple.I'm very happy with the quality of the Tmpeng.You can download it from www.cdrsoft.cc If you have the Dvd x 1.8 version you can go the guide it has help to make videocds using the Tmpeng encoder
  3. I used to do that (and still do, sometimes)... the problem is that the video is not getting ok... the first disc has 2h08min, but dvdx only recognizes 1h43min
    marcelo_magri
    Athlon XP 1600+
    ECS K7S5A
    256 Mb RAM
    Toshiba 6x DVD-ROM
    LG 16x10x40 CD-RW
  4. Try ripping from the disk rather than using DVDdecrypter, see if it still happens...
