Hello. I am a NVIDIA user. I am making some video. I prefere to use GPU for all instead of CPUs. At the momento I want to use ffmpeg via command line. I know that is hard and I am learning howto.
I noticed that with the NVIDIA support ffmpeg runs in seconds instead of hours or days without that support. I run the CUDA widget that shows me how the boards are working: temperature; trottling; memory.
For me it is fantastic. I noriced that the output of editing platforms like Shotcut is fast too.
Via command line there is a problem that is impossible to analyze without the help in the forums because ffmpeg website does not permit an interaction. So I write here.
The problem is the filters support. If I activate the filter in the ffmpeg command line an errour occours and the ffmpeg response is that the filter is unsupported.
There is nothing about that in the ./configure docs. I can run the make command but "how compile with the filters support". Thanks.
see here - https://trac.ffmpeg.org/wiki/FilteringGuide
and here - https://ffmpeg.org/ffmpeg-filters.html
Help needed using ffmpeg on Linux
By tom0184 in forum Video Streaming DownloadingReplies: 2Last Post: 12th Mar 2020, 11:01 -
WARNING: NVidia GTX 1650 doesn't have the Turing encoder's B-Frames support
By hiroo in forum Video ConversionReplies: 4Last Post: 25th Apr 2019, 15:10 -
DVDFab starts to support Linux Systerm
By DVDFab Staff in forum LinuxReplies: 6Last Post: 31st May 2017, 05:12 -
Xmedia Recode and support for NVidia NVENC H.265
By Nick Payne in forum Video ConversionReplies: 3Last Post: 8th Feb 2017, 21:48 -
ffmpeg nvidia-gpu-accelerated encoding using NVENC - commandline settings
By hydra3333 in forum Video ConversionReplies: 3Last Post: 7th Sep 2016, 09:11
