This was my code:
N_m3u8DL-RE --use-shaka-packager -M format=mkv --key 6c8101ca99963428bd608db49e912fd2:885806f096d2526b2 6ebc0d7440634fe "https://vod.streaming.a2d.tv/9dd39cc4-8b43-4dba-a7ce-be966a8b1d3d/7ad43580-48cc-11ee-a97f-e19c58263f14_20522702.ism/.m3u8" --save-name serie
I cant see whats wrong, do you see that?
Results 61 to 80 of 80
wheres the problem?
it downloads, decrypts and merges fine.
youve supplied the key so it doesnt matter if it shows an error about failing to get the key. -
But why cant i decrypt sound, can you please send the key to this serie https://www.tv4play.se/video/d95c4c7c9cf95c7e4c74/avsnitt-1 ? So i can double check if it's the right key
Do you have decrypt the sound (4 sounds it is, Danish, Swedish, Norwegian and Finnish) -
Danish, Swedish, Norwegian and Finnish audio and video is just 1 key. decrypt with mp4decrypt will have a problems with sound but with shaka-packager have sound. i have test them
i dont know why you keeping saying samething over again -
I am very thoughtful, now all of a sudden it works. But I'm very sure that I pressed the same command yesterday but then it didn't work. But now it seems to work, at least I'm sorry for asking, but it didn't work yesterday anyway, but thanks for all the help dears. Appreciated, now I can finally download material myself!
Someone know if this site work https://cdrm-project.com/ to download videos from SF Anytime?
If yes, can someone tell me how, because i use this but not get any key.
[Attachment 77631 - Click to enlarge] -
I'm trying to download from tv4play and I think I have done everything right but with N_m3u8DL-RE I get a lot of errors.
ERROR: Failed to get KEY, ignore.: One or more errors occurred. (The 'data' scheme is not supported.)
ERROR: Failed to get KEY, ignore.: One or more errors occurred. (The 'skd' scheme is not supported.)
The download completes but when I try to play the video all it contains is artefacts. This is the command i run:
UPDATE! With the following command the errors are gone. But still artefacts when I play the video file.Code:N_m3u8DL-RE --use-shaka-packager -M format=mkv --key 53b5ff9a48313161a4aa415358948117:4e17720940794dd0b84aa1737d9837dd "https://vod.streaming.a2d.tv/e26a4b39-bd72-467e-9dc0-92b5597aa14b/e4437d90-9b3e-11ee-9c05-53d8cd5057ab_20527423.ism/.m3u8" --save-name video
Code:N_m3u8DL-RE --use-shaka-packager -M format=mkv --key 53b5ff9a48313161a4aa415358948117:4e17720940794dd0b84aa1737d9837dd "https://vod.streaming.a2d.tv/e26a4b39-bd72-467e-9dc0-92b5597aa14b/e4437d90-9b3e-11ee-9c05-53d8cd5057ab_20527423.ism/.mpd" --save-name video
Its work for me. Its Beck.
But if you try the code again i think you will solve it. I get also "Failed to get KEY" but its work anyways.
Try this codeCode:N_m3u8DL-RE --use-shaka-packager -M format=mkv --key 53b5ff9a48313161a4aa415358948117:4e17720940794dd0b84aa1737d9837dd "https://vod.streaming.a2d.tv/e26a4b39-bd72-467e-9dc0-92b5597aa14b/e4437d90-9b3e-11ee-9c05-53d8cd5057ab_20527423.ism/.m3u8" --save-name Beck_movie
Can someone help me to download this serie from HBO Max?
https://www.hbomax.com/se/sv/series/urn:hbo
eries:GXd2-sQCRRsPCwwEAADce
And tell me how you did, so i can learn me. -
Now i have get the keys but one key i get this 01055ae2301dda766dda20ace735d8a1:00000000000000000 000000000000000
How can i convert the 0 to normal key, because this not work for the video only audio. I cant download HD only SD, can someone here help me with this? -
Do you know a website like this: https://cdrm-project.com/
which can retrieve widevine L1 keys? -
there are other ways. but they certainly won't be shared here in public
one of them is VT. but i'll stop here -
Mp4decrypt syntax
By dzigelbaum in forum Video Streaming DownloadingReplies: 5Last Post: 26th Mar 2022, 02:23 -
mp4decrypt for .mkv ?
By kalemvar1 in forum Video Streaming DownloadingReplies: 9Last Post: 3rd Apr 2021, 13:04 -
Staxrip Error can't encode. how to fix it?
By nattapol in forum DVD RippingReplies: 2Last Post: 13th Mar 2018, 15:20 -
How to fix DVDStyler error
By WhistlerJ in forum Authoring (DVD)Replies: 2Last Post: 20th Mar 2017, 11:24 -
How do i fix an error in ESS.
By jooj in forum SubtitleReplies: 1Last Post: 4th Oct 2016, 16:14
