Hello. I'm new to video editing and have a basic question. I have a whole lot of old Video8 and mini-DV videotapes I recorded, and I'd like to transfer them into digital files that I can edit on Final Cut Pro (once I learn how to edit) and post on YouTube for example. My understanding is that you can capture the video into a digital format using a video-editing software such as Final Cut Pro, or another option would be to do the capturing using a device such as the Cloner Alliance Box Pro or the ClearClick Video Capture Box which I found on Amazon. Which method/equipment/software would you recommend for doing the capture? What are the pros and cons of doing the capture inside Final Cut Pro vs using a device such as Cloner Alliance Box Pro or a similar device?
Thanks in advance!
miniDV is already digital, you just need to transfer it to computer using firewire port (aka iLink), Final cut pro is not a main capture program, capturing is just a side function of it. Analog tapes should be captured with Vdub or AmarecTV on a windows machine and best under Windows 7, None of the stand alone capture boxes you mentioned is recommended, Those are chinese crap.
Thanks for the reply, dellsam34! You recommended I do the capture on a Windows machine. My computer is a mac with Catalina operating system -- is that going to be a barrier or big problem for me to do the capturing?
Poor Video Quality in Digitized Sony Video8 Tapes (Video Attached)
By wsd33904 in forum Capturing and VCRReplies: 7Last Post: 16th Jan 2021, 18:47 -
Converting Panasonic Palmcorder Mini DV tapes to digital videos on computer
By mgsibat in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2020, 19:42 -
Using FireWire to transfer mini-DV tapes to digital files on a PC
By CaptainCatholic587 in forum Capturing and VCRReplies: 15Last Post: 23rd Apr 2020, 23:40 -
Looking to convert hi 8mm tapes to digital via a 2012 MacBook Pro
By Rhetro in forum Newbie / General discussionsReplies: 0Last Post: 19th Nov 2019, 09:12 -
digital video file to mini dv tape
By devdev in forum Video ConversionReplies: 10Last Post: 1st Jun 2019, 17:00
