Hello all! Thanks for having me on the forum!
I am helping a friend to capture some footage; helping because I own many old formats, converters etc.
We're capturing live footage through a JVC gr-ax280 - we like the CCD sensor and the lens, it's got a look we enjoy.
When capturing through a cheap USB capture device, or through my Blackmagic Analog to SDI / Mini Recorder, there are lines present on the capture.
Laced, scan lines. Digital artefacts, I guess.
However, when I use Firewire instead, via my Sony PD150, those lines are not present.
The image without them is much more pleasing to us.
I'd prefer not to have to continue daisy chaining cameras to get the result, so would like to find another solution.
But I can't understand why we're getting such different results. If anyone has any ideas on what could be causing each outcome it would be super useful!
Thank you in advance.
@dellsam34, I'm mentioning you here because I've seen other posts of yours that indicate an interest in this area. I hope you don't mind!
Thank you!
TigerD
The "lines" you see are a normal part of interlaced video. You don't see them with your DV caps because the player/editor hides them from you, by deinterlacing on the fly. The player/editor doesn't know your other caps are interlaced so it's not deinterlacing. When handled properly the "comb" artifacts will not be a problem.
Generally, capturing DV delivers worse quality than capturing raw video and compressing with a lossless codec. But it's a big subject. -
Thanks!
What's confusing is that using the same player/editor, the result is different with DV / other capture. But I'll look further into this, thanks
chinese usb 3 device capture
By codebox in forum Capturing and VCRReplies: 28Last Post: 21st Jul 2021, 16:20 -
I can't capture with Hauppauge USB Live 2
By Lucky Klonoa in forum Capturing and VCRReplies: 6Last Post: 17th Apr 2021, 16:21 -
Out of touch with video capture - USB capture device advice
By Lambchop in forum Capturing and VCRReplies: 7Last Post: 25th Nov 2018, 05:19 -
Firewire / USB / Capture device
By GovertdeKat in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 23rd Nov 2018, 12:01 -
Device not detected on VHS to USB Capture-Converter
By Anonymous754 in forum Capturing and VCRReplies: 10Last Post: 26th Jun 2017, 07:46
