Hi all,
I've recently learned how to download streams with VLC, but I'm running into an issue trying to download full episodes from https://abc.com/shows/malibu-country. I'm able to play the stream in VLC and start saving it, but even though it shows it's going through the full length of the episode, the resulting file only goes to the point of the first ad break if it were being played on the website. I've used both Stream Detector and Video DownloadHelper in order to find the streams, but I get the same results, and no new streams show up when it resumes after an ad break.
Any help would be appreciated!
Results 1 to 14 of 14
You are probably getting one of the a-j.m3u8 (the parts). You just need to get the master m3u8 where all these parts are stored:
E.g. E01:
Code:https://content.uplynk.com/ext/d874124ecca24c88a3c9575e78686acf/e56415377d0048d68215df1431b3ccae.m3u8?cqs=wmwr9BBtjzHjqaLc9owRiMeBOhlOb3o1wVvWJLjh3P4WW5DR5m6wnf1-K9m7z74YyV4_eDu_MB0ASm6h8iQj59sXRmrVeJ025q8lOo3v79jN0GIw_3a-AuX9xMC0_d6ZpOTFCE7AL1B2kqyvel85PY9Wz_SEWNYgGctBPAioEhxUyfXgUCo70gwHtzoIRH9b0w8_J4w3unMA_QiEG5oO9HaEkvHXyJaV8qT2mZsrD50VwJiCn_Psa5gJ-4SFJLMmhpWN7nRx_BGSteC7vzXhI2QHhVciS8uGFhlq7Lx93lOncWjGtPAVrBlfN3VMqglC2EhvfeM8qNVwFuF2GF8qdLE0NtRCzotzXX7KnelqY53gBIQ7DYkG5VClvtnzbvvCxnpMLBJbdujvokrXm4uYKJOG5oOKK2EkAYsXFNtz3nRZdEcfR20c9aZ4ilgtsSkMImjeSU-14K3y8JQCWqT-jfMSTa0VHgOX2bHmIDEfsRs=&kid=4098a6a720374bfcbb4e362b652bcd51
The link expires in around hour,you need to get a fresh one.
First, the main hls link can be obtained with stream detector,it should be the one with tons of symbols (like in screenshot below)
https://i.ibb.co/X7q7XQS/streamdetector.png
Second, if you just paste it as network stream in VLC,it will not work.
You can either save it first with any of the CMD tools (streamlink,youtube-dl,etc), or if you just wanna view it with vlc without downloading, you can use f.e. streamlink and it will open it through VLC,by entering just:
Code:streamlink "https://url" best
Code:[cli][info] Available streams: 54p (worst), 108p, 162p, 252p, 432p, 558p, 594p, 612p, 648p, 720p (best) [cli][info] Opening stream: 720p (hls) [cli][info] Starting player: "C:\Program Files\VideoLAN\VLC\vlc.exe"
Thanks for the explanation. I was able to figure out how to use Stream Detector and FFMPEG, but it's not working for one of the episodes. This episode for some reason it won't find the m3u8, all it's picking up is the ad. Every other episode worked, so not sure what's up with this one.
https://abc.com/shows/malibu-country/episode-guide/season-01/18-new-plans -
youtube-dl "http://content-aeui1.uplynk.com/7366fc7f93904c319632a264029249ce/j.m3u8?exp=1616175827&ct=a&oid=d874124ecca24c88a3c 9575e78686acf&eid=9051bf44bd224cc4922cf98b200604dc &expand=drmOff&iph=bce3c47e96cee433bfcc64b21859597 a15fda18bfc5b2f5c5173090dc30a9de5&euid=CCDBF0D4-ADA7-44B1-BBF2-83667C703274_000_0_001_lf_01-06-00_NA&cdn=ec&stgcfg=datg&rays=hjigfedcba&pp2ip=0&v =3&sig=73144edccf66284bf49d12682f06bd3f9f6d3fed255 4d662a86a988eecdcbcd3&pbs=71f60263f33448048204c683 c97bc633"
I really appreciate the help, unfortunately i'm getting an error:
hls @ 000002011cfee400] Error when loading first segment 'http://x-default-stgec.uplynk.com/ausw/slices/736/d874124ecca24c88a3c9575e78686acf/7366fc7f93904c319632a264029249ce/FP_J00000000.ts?x=0&euid=356CF527-7880-4430-B7E8-F548644FF44C_000_0_001_lf_01-06-00_NA&drm=1&si=0'
http://content-aeuf1.uplynk.com/7366fc7f93904c319632a264029249ce/j.m3u8?exp=1616170025...58%20fa4bc359: Invalid data found when processing input
ERROR: ffmpeg exited with code 1 -
Yeah, i ran it as a youtube-dl command just like they provided, but that's the error I got.
C:\Users\ajvan>youtube-dl "http://content-aeuf1.uplynk.com/7366fc7f93904c319632a264029249ce/j.m3u8?exp=1616170025&ct=a&oid=d874124ecca24c88a3c 9575e78686acf&eid=9051bf44bd224cc4922cf98b200604dc &expand=drmOff&iph=2af2b4264913a7203877ddd9b835 f4a 981c7246e7045cb7854d1beaaba948737&euid=356CF527-7880-4430-B7E8-F548644FF44C_000_0_001_lf_01-06-00_NA&cdn=ec&stgcfg=datg&rays=hjigfedcba&pp2ip=0&v =3&sig=de791b9d19f8186261320d2eecd1c6d7427158a98f 2 4916ac0d6db545c4dd4b1&pbs=c58347b54c844042a7a30858 fa4bc359"
[generic] j: Requesting header
[redirect] Following redirect to http://content-aeuf1.uplynk.com/7366fc7f93904c319632a264029249ce/j.m3u8?exp=1616170025...858%20fa4bc359
[generic] j: Downloading m3u8 information
[download] Destination: j-j.mp4
ffmpeg version 4.3.2-2021-02-27-full_build-www.gyan.dev Copyright (c) 2000-2021 the FFmpeg developers
built with gcc 10.2.0 (Rev6, Built by MSYS2 project)
configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-lzma --enable-libsnappy --enable-zlib --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libzvbi --enable-librav1e --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
libavutil 56. 51.100 / 56. 51.100
libavcodec 58. 91.100 / 58. 91.100
libavformat 58. 45.100 / 58. 45.100
libavdevice 58. 10.100 / 58. 10.100
libavfilter 7. 85.100 / 7. 85.100
libswscale 5. 7.100 / 5. 7.100
libswresample 3. 7.100 / 3. 7.100
libpostproc 55. 7.100 / 55. 7.100
[hls @ 0000018502c8e400] Skip ('#EXT-X-VERSION:5')
[hls @ 0000018502c8e400] Skip ('#UPLYNK-SEGMENT: 7366fc7f93904c319632a264029249ce,00000000,segment' )
[hls @ 0000018502c8e400] Skip ('#EXT-X-PROGRAM-DATE-TIME:2021-03-19T17:43:32.320000+00:00')
[hls @ 0000018502c8e400] Skip ('#EXT-X-DISCONTINUITY')
[hls @ 0000018502c8e400] Skip ('#EXT-X-PROGRAM-DATE-TIME:2021-03-19T17:48:59.188208+00:00')
[hls @ 0000018502c8e400] Skip ('#EXT-X-PROGRAM-DATE-TIME:2021-03-19T17:56:14.836208+00:00')
[hls @ 0000018502c8e400] Skip ('#EXT-X-PROGRAM-DATE-TIME:2021-03-19T18:03:02.308208+00:00')
[hls @ 0000018502c8e400] SAMPLE-AES encryption is not supported yet
[hls @ 0000018502c8e400] Failed to open segment 0 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 1 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 2 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 3 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 4 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 5 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 6 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 7 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 8 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 9 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 10 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 11 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 12 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 13 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 14 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 15 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 16 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 17 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 18 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 19 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 20 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 21 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 22 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 23 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 24 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 25 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 26 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 27 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 28 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 29 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 30 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 31 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 32 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 33 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 34 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 35 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 36 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 37 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 38 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 39 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 40 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 41 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 42 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 43 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 44 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 45 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 46 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 47 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 48 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 49 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 50 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 51 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 52 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 53 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 54 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 55 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 56 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 57 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 58 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 59 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 60 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 61 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 62 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 63 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 64 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 65 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 66 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 67 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 68 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 69 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 70 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 71 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 72 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 73 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 74 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 75 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 76 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 77 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 78 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 79 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 80 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 81 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 82 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 83 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 84 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 85 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 86 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 87 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 88 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 89 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 90 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 91 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 92 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 93 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 94 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 95 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 96 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 97 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 98 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 99 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 100 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 101 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 102 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 103 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 104 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 105 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 106 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 107 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 108 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 109 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 110 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 111 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 112 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 113 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 114 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 115 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 116 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 117 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 118 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 119 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 120 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 121 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 122 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 123 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 124 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 125 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 126 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 127 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 128 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 129 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 130 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 131 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 132 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 133 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 134 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 135 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 136 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 137 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 138 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 139 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 140 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 141 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 142 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 143 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 144 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 145 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 146 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 147 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 148 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 149 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 150 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 151 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 152 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 153 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 154 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 155 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 156 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 157 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 158 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 159 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 160 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 161 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 162 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 163 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 164 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 165 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 166 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 167 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 168 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 169 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 170 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 171 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 172 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 173 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 174 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 175 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 176 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 177 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 178 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 179 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 180 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 181 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 182 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 183 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 184 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 185 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 186 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 187 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 188 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 189 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 190 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 191 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 192 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 193 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 194 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 195 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 196 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 197 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 198 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 199 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 200 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 201 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 202 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 203 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 204 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 205 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 206 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 207 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 208 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 209 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 210 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 211 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 212 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 213 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 214 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 215 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 216 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 217 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 218 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 219 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 220 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 221 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 222 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 223 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 224 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 225 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 226 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 227 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 228 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 229 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 230 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 231 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 232 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 233 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 234 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 235 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 236 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 237 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 238 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 239 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 240 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 241 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 242 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 243 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 244 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 245 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 246 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 247 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 248 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 249 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 250 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 251 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 252 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 253 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 254 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 255 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 256 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 257 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 258 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 259 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 260 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 261 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 262 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 263 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 264 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 265 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 266 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 267 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 268 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 269 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 270 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 271 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 272 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 273 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 274 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 275 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 276 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 277 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 278 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 279 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 280 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 281 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 282 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 283 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 284 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 285 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 286 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 287 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 288 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 289 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 290 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 291 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 292 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 293 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 294 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 295 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 296 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 297 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 298 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 299 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 300 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 301 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 302 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 303 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 304 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 305 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 306 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 307 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 308 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 309 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 310 of playlist 0
[hls @ 0000018502c8e400] Failed to open segment 311 of playlist 0
[hls @ 0000018502c8e400] Error when loading first segment 'http://x-default-stgec.uplynk.com/ausw/slices/736/d874124ecca24c88a3c9575e78686acf/7366fc7f93904c319632a264029249ce/FP_J00000000.ts?x=0&euid=356CF527-7880-4430-B7E8-F548644FF44C_000_0_001_lf_01-06-00_NA&drm=1&si=0'
The 'm3u8' URL can only be used once.
Help downloading from ABC
By Owent10 in forum Video Streaming DownloadingReplies: 0Last Post: 21st Sep 2020, 16:04 -
Need Help with ABC Video
By hypnicjerk in forum Video Streaming DownloadingReplies: 4Last Post: 21st Sep 2020, 10:37 -
ABC.COM help/fix needed please
By blade2005 in forum Video Streaming DownloadingReplies: 7Last Post: 24th Jun 2020, 15:17 -
Subtitles from ABC
By Boldest06 in forum SubtitleReplies: 2Last Post: 20th Nov 2019, 15:46 -
Virtualdub captured video has full horizontal lines when played on VLC
By zymok in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2017, 08:04
