Hello!
I have been tasked with fixing my dad's pioneer 469h HDD DVD recorder. We replaced the hard drive no problem but haven't found anyone with a service disc! Anyone have any luck finding one or leads on one in 2021? Willing to pay to get this fixed as Dad does use this for his home business (preserving precious memories from all forms of tape onto dvd). Any help appreciated!
Thanks!
Katrina
A desperate daughter!
Results 1 to 14 of 14
The Pioneer DVR-550 is an excellent unit, sorry to hear yours is ailing.
You need a "Type 2" Service Disc, usually version GGV1321. These were most commonly obtained with the help of the PioneerFAQ enthusiast website, which was unfortunately forced to close down last year due to mounting expenses vs dwindling interest in DVD recorders. Nearly all discussions and links to Pioneer service materials point back to that now-defunct site.
If you are patient and wait a week or so, the proprietor of PioneerFAQ will probably notice this thread and offer some assistance. He goes by the member name "Hkan" here on VideoHelp, but doesn't frequently post anymore because DVD/HDD recorders are a dead product category that fewer and fewer people are interested in discussing as years go by. I'd suggest you send a PM directly to Hkan, letting him know you need help getting a service disc: he is the best source of advice among us remaining Pioneer users.
Note you will need a Service Remote along with the service disc: if you don't already have the special remote, generic versions are still available from dealers like this one. I recommend looking specifically for the "Sony" service remote instead of the "Pioneer": they function exactly the same, but generic service remotes marketed specifically for "Pioneer" are priced 2x-3x higher (due to the much higher awareness and demand for the Pioneer name).Last edited by orsetto; 18th Mar 2021 at 19:51.
Looks like the last time hkan logged onto VH was about a month and a half ago, so I wouldn't expect him to see this post in a timely manner, I'd agree with the PM which if he has notifications turned on, he should get an email.
Thank you for the responses! I will make sure to send that message, and we have ordered the service remote as of this afternoon. My dad is disabled, but always had a knack for all things audio and video, starting in the 1990's with a VHS player that we could convert PAL to NTSC. It's since gone onto taking peoples home movies on betamax, mini dv, basically any format that has been able to be in a home video recorder, and putting them to DVD. We have repaired broken tapes, managing to salvage all the tape and get it put onto DVD to save the memories. So this machine is really special to him, and definitely worth repairing to keep the customer's happy, and a little income flowing. Thank you so much for the information. It has been very very helpful!
Katrina -
Katrina,
It appears neither you nor your father has ever previously replaced the HDD in a Pioneer recorder. While a simple enough task that takes less than ten minutes once you get the hang of it, the necessary steps involved are a little tricky and counterintuitive to those haven't yet performed the procedure. Many instructions posted on websites, even the esteemed PioneerFAQ, leave out some tiny piece of info or present it in a confusing manner. In the interest of saving you some time and frustration, below please find my own personal checklist of steps. I wrote this up some years ago after stumbling across a couple of small but key points that were missing from the websites I'd consulted:
1. Remove all connecting cables from the recorder including the power cord. Let the unit sit for about an hour, so the interior has a chance to cool down to comfortable room temperature. During this time, examine the layout of the service remote and memorize the locations of the ESC, STEREO (or STER), STOP, CLEAR and SEARCH buttons. You will need to be able to find and press these quickly.
2. Look on the 450 rear panel for a secondary small white label with a bar code and nine-digit code number, its located near the fan or the AC socket. Write down the nine digits, or take a pic of the label with your phone: you will need this code number later.
3. Remove the screws from the cabinet sides and the rear panel that hold the top cover in place. Set aside the screws, noting which were on the sides vs the back panel (the side screws are slightly different on some models). Remove the top cover by pulling out the bottom side edges slightly and tilting the cover up at the rear until you can pull it out of the front bezel. Set the cover aside.
4. With the cover off, use your phone to take photos of the inside, particularly the arrangement of any silver, yellow or white adhesive tapes and pads that might be affixed to the HDD and/or its bracket. Once you have the pics, look for three or four screws holding the bottom of the HDD bracket to the chassis. Remove these and et them aside, noting where they came from (there are different types of screws holding the bracket to the unit and the HDD to the bracket). CAUTION: be very careful not to let your hand slip and poke your screwdriver into the power supply section! This can short out the circuits with any power left in the storage caps, destroying the recorder (ask me how I learned that the hard way).
5. Use your judgement about the best way to unplug the red/black power and data cables from the HDD. Sometimes its easier with the HDD half pulled out of the unit, sometimes with it fixed in place. Whatever you decide, unplug the cables.
6. Remove the bracket with attached HDD from the unit. You might need to cut a plastic cable tie to free the bracket, and do some acrobatic wiggling to get it out.
7. Carefully (VERY carefully) peel off any cushion pads and silver or yellow or white tapes from the HDD and/or bracket, and set them aside.
8. Remove the four screws holding the HDD in the bracket, set them aside. Remove the original HDD from the bracket and set aside.
9. Fit the new HDD into the bracket, and replace the screws that hold it in the bracket.
10. Refer to the photos you took, and carefully put all tapes and pads back onto the HDD and/or bracket in the same places they were before.
11. Plug the power / data cables back into the HDD, and maneuver the HDD / bracket back inside the recorder. Make sure it seats properly with the feet of the bracket sitting flat on the chassis. Eyeball the bracket feet to be sure you have each screw hole lined up with the matching hole in the chassis. Replace the bracket screws.
12. Replace the top cover and all required cover screws. Connect the power cable, and the HDMI cable to your TV.
13. Power up the 450 and it will flash HDD ERR or CPRM Err on the front panel as well as your TV screen. This means you need to "marry" the distinctive CPRM code of the recorder motherboard to your new HDD, which requires the service remote and service disc.
14. On your service remote, press ESC and then STEREO. Service mode will activate and a service display will appear on your TV. Enter the nine-digit number you wrote down or photographed earlier, using the service remote number keys, then press STOP.
15. Press ESC then STEREO again, enter the nine digit number again, and press SEARCH.
16. The recorder will ask for the ID Data Service Disc. Load the service disc and close the tray. After a moment, your TV should display "Rom Write OK!" (If your TV displays Rom Write NG! instead of Rom Write OK!, don't panic. Sometimes the recorder trips over itself, or you enter the nine digits in the wrong order, so have to repeat steps 14 thru 17 over again. It nearly always "takes" the second time around.)
17. Press CLEAR on the service remote. The recorder will exit service mode. Remove the service disc BUT DO NOT CLOSE THE TRAY. Turn the recorder off, and the tray will close itself. PUT THE SERVICE REMOTE AWAY. Wait a moment, and turn power back on with the front panel button or the normal 450 remote. Your 450 should now start up normally with no ERR alerts from this point on.
When you press the HDD Nav button on the normal 450 remote, it should display an empty hard drive recording list, showing how many hours can be recorded on it. Usually this will be approx 80 hours with a 160GB HDD and the recorder set to SP recording speed. Note the recorder usually will not recognize or use the full capacity of HDDs larger than 160GB (i.e. if you install a 500GB HDD the recorder will only use the first 160GB of it).
A couple of clarification points that aren't always obvious from reading similar instructions posted elsewhere:
During steps 14 and 15, you will be entering the CPRM number *twice.* A lot of people don't realize this and get stuck. Step 14, you hit ESC+STER, enter the number, press STOP. Step 15 you hit ESC+STER a second time, enter the number a second time, then press SEARCH (instead of STOP).
In step 17, be careful NOT TO CLOSE THE DISC TRAY after removing the service disc. Just take out the disc and turn off the power, the 450 will close the tray by itself. If you close the tray by hand before turning off the power, the entire CPRM process can get corrupted resulting in HDD Err, meaning you have to start the whole thing over from Step 14.
All this is far easier/quicker to do than describe
. I broke it down into many small steps to make sure anyone could follow it even if they'd never opened anything electronic in their lives. Hope this helps smooth the way for you!
@orsetto
Thank you for this awesome info in 2021 year
I have few questions I have Pioneer dvr 560h everything work perfect but I wanna replace HDD to SSD and maybe even made modification to easily disconnect/connect ssd without opening case.
1. Can I use GGF1381 remote what is available in Logitech Harmony remote? I tested entering to service menu and works.
2. Disc here is ok for my recorder https://archive.org/details/pioneer-ggv-1305-type-2-service-disc ?
3. Is the tutorial above identical for my 560h?
Thank you. -
@ prodarek,
Glad you are finding my post helpful in updating your Pioneer 560!
Re your questions:
1. Yes, the Harmony codes for GGF1381 do emulate the correct Pioneer service remote.
2. I'm not absolutely sure if the 1305 disc is completely compatible with your 560. The 1305 debuted along with the earlier 540/543/640 series, which are mostly identical to the later 550 and 560 series. However the 540/543/640 contain old-school EIDE-based HDDs vs the more modern SATA connections in the 550/560 units. From personal experience, I can confirm the newer 1321 service disc is backward-compatible with all models in the x40, x50, x60 series (but I no longer own the 1305, so cannot verify it is forward-compatible with the 550/560). If at all possible, using the later 1321 disc is preferred to guarantee success.
3. Yes, the tutorial I posted applies to every Pioneer recorder ever sold (aside from older pre-540 models requiring a different "Type 1" service disc). -
Hello,
So not bad news
there is chance. Ok so I will try get 1321 disc this will be safer even manual service talking about 1321.
Thank you.
Btw
pioneerfaq.info still alive
https://web.archive.org/web/20170820115806/pioneerfaq.info/english/replace_HD.php?play...question=Part2 -
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
Orsetto, although your instructions were quite comprehensive, did you forget the part about going into the user menus with the regular remote control, and initializing (formatting) the HDD? This usually (always) needs to be done AFTER the "ID Data" disc is removed and the machine is powered off and on.
Also, as far as not closing the drawer, I usually hit "clear" on the service remote and then close the drawer with the front-panel button, then turn the machine off. I've done this at least 100 times! (I use a lot of HDDs!)
Finally, as I mentioned in another thread, the x50 machines can format a drive up to 1TB... you can then put the drive in an x60 machine and go through the complete service remote procedure again, but NOT the initializing in the user menus, and you will have a 1TB drive in a 560 or 660! And it appears you can swap a hard disk with data between any 550/560/650/660 machines "simply" by doing the service remote procedure again.
--Gary -
@Gary,
Sorry to note that the last VH post by orsetto was something like a couple years ago. This almost certainly equates to last visit to VH. I have one or two PMs sent to him that remain unanswered for quite awhile now. I hope that he is doing O.K. (managed to transit the Covid era and whatever else, in reasonably good condition). His absence here -- and that of jwillis84 -- is sorely missed. He always made great contributions to a number of forum threads, which helped out many of us.
I have one thing to add that would be more in line for jwillis84: I've just passed 545 entries on one of my Pio DVDRs -- which was supposedly way out there past the "forbidden zone." (Many of these items are rather brief.) There are over 14H remaining, at my default setting of MN21. This quantity may amount to skating on thin ice, but so far I have been getting away with it. But I probably should archive off a lot more of the entries that have some claim to being keepers.Last edited by Seeker47; 19th Feb 2024 at 15:07.
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
A word of caution for you all: Do not try going back to the original url for the now defunct pioneerfaq.info site ! It now seems to be inhabited by (or redirects to) one of those phony "You have serious malware infections, but WE can fix it" scam sites. Not this one but another similar one thoroughly trashed a browser I had on another computer. These things are prevalent online. I don't know if just getting to the site was enough to cause this, or whether it was something encountered on that web page. It was a laborious and not entirely successful process to recover from that. I was lucky that the damage seemed to be confined to that one browser, rather than the computer as a whole. Could not in the end save that browser though, and some good info within it was lost. Had to just replace the browser with a much later version, after deleting the compromised one.
So, stick to the Wayback archived copies like the one linked in this thread. Unfortunately, the inside-the-DVDR photos from Part 1 of this guide never got archived, or else are no longer there for some reason.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
This may be as good a choice of thread to post this in as I'm apt to find -- despite it carrying the "Old Thread" caution.
orsetto returned this Feb. (2025) just long enough to leave me an "I'm O.K." PM, which I was most gratified to receive and to which I replied, before promptly vanishing again. [I very much hope that he may return to us, at some point.] This post will serve as an illustration that you are apt to forget even some rather basic stuff when you have not done something even ever-so-slightly technical for quite awhile. Abetted by the natural deterioration of memory, as one climbs the age ladder.
I made a recording of an 1H:49M item somewhat oversized, by recording it at MN26, because I wanted a better compromise for the quality of some of the images therein. So it came out to be 4.9 GB in size, larger than 'R' or 'RW' disc size . . . and I did not want to go to the trouble of doing it all over again at -- say -- MN 24, in order to achieve a better fit. The obvious conclusion was to use one of my dwindling supply of dual layer Verbatim blanks for this. Here's where the confusion came in. (This was being done on a Pio 460.) I mistakenly thought that the disc needed to be initialized first, because I honestly did not remember one way or the other, and then was discomfited to run into greyed out options for all of the initialization options, and its attendant "You Can't Get There From Here." After then trying this on the blank using another Pio DVDR upstairs, with the very same results, my first wrong thought was that it could be because the disc was from a UAE origin spindle of them, rather than a Singapore one, or that over time the disc had simply gone bad. But this same result got repeated with another blank, this time from a Singaporean spindle of the Verb DL. Second wrong thought was "Oh CRAP, the lasers in these Pio DVDRs may finally be failing," and this is the first symptom of that. Both of those notions will be incorrect though. And now I conclude this fact much more so than I actually remember it: the -R and DL/R discs do not need any initialization, and you cannot do it. Only the rewriteables (RW) need this. Even though I vaguely recall doing it for +R discs, but am quite possibly wrong on that score as well. (It's annoying, having such a fundamental lapse. Which is why I started writing down the procedures for a lot of things, a few years back. But not in this case.)Last edited by Seeker47; 5th May 2025 at 11:35.
Pioneer DVR-510H-S GGV1179 data disc download
By viperss in forum DVD & Blu-ray RecordersReplies: 31Last Post: 30th Mar 2021, 09:57 -
Wife's Dell HDD crashed - dead. Windows re-install on new HDD questions.
By hech54 in forum ComputerReplies: 9Last Post: 11th Jun 2019, 04:19 -
"HDD NG" displayed after HDD replacement on Panasonic DMR-EH60
By Bud5 in forum DVD & Blu-ray RecordersReplies: 21Last Post: 14th Mar 2017, 08:33 -
Transferring DVDs to HDD and playing them from the HDD
By johnsees in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Oct 2016, 08:13 -
Pioneer DVR-460H-K failed HDD
By turky in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Apr 2016, 10:48
