Is there any video/hi8 players that can play both PAL and NTSC?
Yes but NTSC will be played back in PAL60 not true NTSC, Not all capture devices can capture that format, And it's a little bit damaging to the already fragile chroma since the PAL player re-encodes it in a PAL chroma scheme (4.43 MHz). NTSC best captured in 3.58 MHz with a native NTSC player.
Ok, thanks. It was something like this i expected. So then i will buy a NTSC also..
Just look for D8/Hi8 camcorders, They are cheaper than the home decks, Most of them have very little use, Some are built in line TBC and S-Video out (which is what you want for capturing), Don't take any chance with 8mm home deck, you will be disappointed.
Converting NTSC->PAL Interlaced DVD Back To NTSC 24FPS???
By SegaSonic91 in forum DVD RippingReplies: 7Last Post: 2nd Oct 2020, 23:55 -
Betamax Player Dual Format - NTSC & PAL
By johnoshea02 in forum Capturing and VCRReplies: 3Last Post: 27th Feb 2020, 12:40 -
What do you consider the "best" PAL/NTSC/SECAM VHS player?
By flyboynm in forum MediaReplies: 3Last Post: 7th May 2019, 22:35 -
Hi8 XR PAL - what resolution?
By kamild1996 in forum Capturing and VCRReplies: 1Last Post: 21st Dec 2018, 07:25 -
Can a PAL DVD Recorder capture signals from a NTSC Hi8 camcorder?
By guy24s in forum DVD & Blu-ray RecordersReplies: 8Last Post: 3rd Dec 2018, 09:33
