Hi, I did not think of this factor before, i came across that one of the devices connected to the computer is not hdcp supported device alert. From then on, I could not see the signals from the source device to the sink device, or connected device.
are the versions of hdmi cable determining the hdcp status of a device.
Are the cabling inside the versions of different kinds of version, are made differently.
Say, that these are made so that , it does not pass on to the other devices that is connected to the second device
please say something on this
NO.
Only difference between the cables is:
1. Support for ethernet channel or not
2. QUALITY of build (=ability to go longer, or to accommodate higher bitrates, WITH less interference/noise)
That's it.
ALL must support HDCP. But that isn't your issue.
HDMI to Coaxial ( cable) cable adapter
By zmann96 in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2019, 15:21 -
Want an HDMI timer recording device for Time Warner Cable
By tthomasjr in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2017, 23:56 -
HDMI capture without need for hdcp stripper?
By david151 in forum Capturing and VCRReplies: 4Last Post: 15th Oct 2016, 10:42 -
Am I out of luck if I want a HDMI splitter that strips HDCP 2.2 in the US?
By Cyber Akuma in forum Capturing and VCRReplies: 55Last Post: 15th Oct 2016, 04:56 -
HDMI cable Version for Stripping HDCP?
By hotlips69 in forum Capturing and VCRReplies: 14Last Post: 7th Jul 2016, 20:51
