I've downloaded this movie to find out there's
no audio. Now, what could've possibly caused
this problem? The movie's in two AVI files, and
I've checked each part for sound, and nothing.
Where do I start to troubleshoot this problem?
If there's any further info you need, I'll keep
an eye out in the forum.
TIA
Turk
Results 1 to 10 of 10
Why doesn't this work?
Usually that is a codec problem, I suggest you try installing Kristal Studio Codec Pack, it always worked great for me.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
For the life of me I can't seem to find the Kristal StudioOriginally Posted by Sefy
Codec Pack. So I substituted the Nemo Codec Pak, and
you were right. I now have sound, but the video is slow
and choppy. I even installed v3.11 along with v4.12, but
the problem returned, and video is back to excellent.
Will you give me a link to the Kristal Studio Codec Pack?
You've diagnosed the problem, now maybe you can give
me the medicine.
Why doesn't this work? -
Here you go
http://screw.wz.cz/test/codecs.htmEmail me for faster replies!
Best Regards,
Sefy Levy,
Thanks again Sefy. I'll let you know how it goes.Originally Posted by Sefy
TurkWhy doesn't this work? -
Well, that didn't work at all. It actually made it worse.Originally Posted by Sefy
Now WMP won't play anything, it just crashes.
I'm using the "recommended" codec from the site.
Maybe I should try the 'Alpha"? I'm running WinXP.
I'll continue to keep you abreast of the goings on.Why doesn't this work? -
Does it make a difference?
I've having a HELL of a time finding a codec that'll play
this particular movie. Either I have good audio with no
video, or vice versa.
The actual plan has never been to play the movie on
the computer anyway. I just like to verify I've got all
the parts and such. The intended player has always
been my standalone DVD/VCD/SVCD player.
So I guess my question is, does it make a difference
that I don't have audio on the computer. Will I have
audio on the VCD?
TIA
The problem is that you have too many codecs installed, I suggest you uninstall them all, and then JUST install the Kristal Studio, no Alpha no nothing, JUST the Kristal Studio codec pack!
Best Regards,
Sefy Levy,
I never upgrade anything unless specifically required.Originally Posted by Sefy
In all the cases, I uninstalled and installed the new one.
I've since gone back to DivX v5. Now its back the way
it was.Why doesn't this work? -
Back the way it was how ? not working ? or is it working now ?
Best Regards,
Sefy Levy,
Hardsubs Easy
By kazz0817 in forum SubtitleReplies: 1Last Post: 22nd Jan 2011, 05:44 -
is there an easy way to get trailers off of my blurays?
By AndyD in forum Blu-ray RippingReplies: 4Last Post: 18th Dec 2010, 12:57 -
easy way to embed video
By butterflies in forum Video Streaming DownloadingReplies: 9Last Post: 11th Oct 2010, 13:27 -
Is there any easy way
By kemcel in forum MediaReplies: 1Last Post: 17th Mar 2009, 09:07 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 15:43
