Hello everyone!
I was looking for some help to fix a seriuos problem I'm currently having with AVI videos conversion and I found this forum.
Hoping you're all doing fine and healthy, I explain the issue:
I use Adobe After Effects 2019 to make video compositions with subtitles. Videos are no longer than 2 minutes and have a 4-7 GB of weight. At the beginning, I used to use VLC Player to convert videos with H264 code and reach a weight of 40 to 120 mb, but it suddenly started causing audio problems (it doesn't work, even mantaining the original audio). So, I found Wondershare Uniconverter and it was ok till I tried to convert a 6 GB AVI video. When I import the original video (edited with AE), it shows a black and white preview with distorsion and, of course, the result has it too.
[Attachment 57832 - Click to enlarge]
Thumbnail preview.
[Attachment 57833 - Click to enlarge]
Converted video preview vs original video.
What have I tried so far?
- Reinstall Wondershare Uniconverter (didn't work)
- Try to convert another video with similar parameters (didn't work)
- Try to convert another video recorded with a smartphone (it worked but no when I process it on AE)
- Try to restore Wondershare Uniconverter preferences (didn't work)
Help, pls.
Stay safe!
	try Vidcoder.
 https://www.videohelp.com/download/VidCoder-6.25-Beta.exe
 Post a mediainfo report (text view) of your source file
	General
 Complete name : C:\Users\Samsung\Desktop\ad_5esa4.avi
 Format : AVI
 Format profile : OpenDML
 File size : 6,89 GiB
 Duration : 56 s 323 ms
 Overall bit rate : 1 051 Mb/s
 Recorded date : 2021-03-16T04:07:46.522043
 Vídeo
 Format : RGB
 Codec ID : 0x00000000
 Codec ID/Info : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
 Bit rate : 1 049 Mb/s
 Width : 1 350 píxeles
 Height : 1 080 píxeles
 Display aspect ratio : 5:4
 Frame rate : 29,970 (30000/1001) FPS
 Color space : RGB
 Bit depth : 8 bits
 Bits/(Pixel*Frame) : 24.012
 Time code of first frame : 00:00:00:00 / 00:00:00:00
 Time code source : Adobe tc_A / Adobe tc_O
 Stream size : 6,88 GiB (100%)
 Audio
 Format : PCM
 Format settings : Little / Signed
 Codec ID : 1
 Bit rate mode : Constante
 Bit rate : 1 536 kb/s
 Channel(s) : 2 canales
 Sampling rate : 48,0 kHz
 Bit depth : 16 bits
 Stream size : 10,3 MiB (0%)
 Alignment : Alineación intercalados
 Interleave, duration : 939 ms (28,13 fotogramas de vídeo)
 Interleave, preload duration : 967 ms
	This will occasionally cause problems with some software like you've seen:
 because it's not divisible by 4Code:Width : 1 350 píxeles
  avi playing and conversion issueBy NMeins in forum Video ConversionReplies: 6Last Post: 2nd Nov 2020, 16:21
  UniConverter v 12 trouble with looping back to the first video?By Kopter6 in forum Authoring (DVD)Replies: 0Last Post: 20th Aug 2020, 07:49
  Problem with Wondershare UniconverterBy momonone in forum Video ConversionReplies: 1Last Post: 21st Jun 2020, 09:23
  Wondershare Video Converter Free 6By jcool26 in forum Video ConversionReplies: 1Last Post: 2nd May 2020, 13:14
  Can't find Advanced Editing in Wondershare UniconverterBy genistas in forum EditingReplies: 2Last Post: 11th Mar 2020, 04:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
