Hello,
I have a Pioneer A03 DVD writer.
When i used Nero 5572 for the first time to write a DVD-R, it gave me the choice of using x1 or x2 speed for burning since DVD-R can be burned at x2.
Then i used a DVD-RW and the only choice was x1. it's normal.
But, since this moment, i cannot return to x2 speed even if i insert a DVD-R. It only display x1 in the speed selection box while it has detected a DVD-R disk.
I tried to reboot, same problem.
Can someone tell me how to get x2 speed option back?
Put in a V2 or higher DVD-R. You are probably using generic media (version 1.0, no doubt). NERO will detect this and set the available speeds accordingly.
Laptop IEEE 1394 doesn't recognize camcorder
By NautTboy in forum Capturing and VCRReplies: 4Last Post: 21st Jan 2010, 21:15 -
DVD player doesn't recognize XVID files
By Theodorist in forum DVD & Blu-ray PlayersReplies: 11Last Post: 18th Jan 2010, 00:42 -
Doesn't recognize the Blue Ray disk
By bryankendall in forum Newbie / General discussionsReplies: 6Last Post: 18th Jul 2009, 10:15 -
Suddenly, burner doesn't recognize blank DVD
By slats7 in forum ComputerReplies: 9Last Post: 13th May 2008, 12:10 -
PSP doesn't recognize format
By rqthrottle2 in forum ffmpegX general discussionReplies: 5Last Post: 6th Jan 2008, 14:32
