I have an AGPTek media player but can't seem to get the subtitles to play along side the video. I've tried making sure both files have the same name and are in the same folder and press the subtitle button when the videos playing . Even my old WD Media Player worked with that. Anyone know how to get this to work.
I see there a number of standalone media players out there. Is there one that'll do this without a problem?
Looking at the remote, it does have a subtitle button so what file type video is it and the subtitle file is it srt?
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
You might need to merge the subtitle for it to work.
This same problem is covered in these posts from last year https://forum.videohelp.com/threads/397831-Mini-media-player-doesn-t-show-subtitles Maybe there is a solution mentioned.. I didn't read all of the comments.
what are the subtitles formatted as ?? if this is your player - https://www.amazon.com/AGPTEK-Player-Remote-Optical-output/dp/B01CCRYIN8
it says under file format that it supports: Subtitle: SUB, SRT, SSA, SMI -
Hi, jaca, Simplly download the vlc media player and you get what you want. As you have known that the files are to be in the same folder. srt is the comman format for easy capture.
Just open the video and in the subtitle menu select the srt file.
The vlc would auto capture srt files if you open the video, provided the srt in the same folder.
The vlc is also having a menu called vsub, from which you just play the video and clicking this would provide the download link for srt for your video , if it is a movie, and it will play with synced subtitles below the video.
Video from ok.ru cant play on VLC if subtitles are on
By supercain in forum Video Streaming DownloadingReplies: 8Last Post: 19th Aug 2025, 03:01 -
How to play movie with 2 subtitles on a chrome cast ?
By i3arty in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2021, 18:37 -
mpc play episode from playlist which was openned last, disable subtitles
By empleat in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jun 2018, 06:44 -
Play Subtitles from HDD using DVD player
By ausrob in forum SubtitleReplies: 2Last Post: 14th Mar 2017, 09:19 -
Play subtitles by line
By PannenkoekenNL in forum SubtitleReplies: 5Last Post: 18th Dec 2016, 16:23
