I muxed 2 files properly, but the audio track was bigger (Atmos) than the original ( DD5.1). Would the Atmos file be off in tracking regardless because it's bigger? It's ahead by a second or two. How do I roll back the audio with MKV?
Results 1 to 9 of 9
If "bigger" means the file size is bigger, that doesn't matter. If you mean the running time is longer that could be a problem.
Use the "Delay (in ms):" field to delay an audio track. If the audio track needs to be advanced use a negative delay. -
Yes bigger as in the 2 audio tracks Atmos/DD5.1 is bigger in size. The run time is the same. Ok I will try that. I do that before I mux? Does that I mean have to keep "remuxxing" with 1-2-3..etc different settings to get a track right? I tried Project Meterorite (no good). I appreciate your help. Thanks.
IN options Playback/sync render settings ? That's a bit complicated for me. Mine is greyed out too. If that's the right area?Thanks
Don't know what +/- refers to? I do know that nothing works inside that window (like I said all grey). I appreciate your help. Too big for me. I am moving on. Thanks
While the video is playing press + (advance audio) or - (delay audio) keys on the numeric keypad of your keyboard.
about MKVToolNix
By ujang in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2018, 22:32 -
MKVToolNix Help!
By Alekos65 in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2017, 00:26 -
MKVToolNix
By ThomasCSR in forum Video ConversionReplies: 6Last Post: 14th Jun 2017, 11:19 -
MKVToolNix 9.7.1 help
By zcool2016 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jan 2017, 01:07 -
Need help using MKVtoolnix
By Larold in forum SubtitleReplies: 8Last Post: 6th Apr 2016, 07:00
