Hi
I was bought this player recently, and along with it some R1 DVD's. They don't play, and I have tried everything to find a code/hack etc to open it up.
I have spent 7 hours today googling incessantly, and even went and bought a OneForAll remote as the main solution was a code hack.
Btw, the OneforAll that seems to work for most people doesn't for me. Step5 (Code 5) doesnt seem to get a response from the remote, but the other 4 do.
Can someone, ANYONE, please help me and put me out of my misery
Have been quoted £200 to mod it, but would rather avoid if possible.
Fingers Crossed!!
Sonys usually aren't crackable (easily).
If your country allows such a thing: Get a DVD writer. Get dual layer DVDs. Get a piece of software to make a legal copy. Make legal copy and watch that.
Most DVDs are only marginally larger than dual layer media so by shrinking menus etc. or copying only the film you will see no difference in quality.
You can also use software like VLC that ignores region codes on any drive with a drive...
looking for hack for region 1 Sony DVP-NC615
By occhiv in forum DVD & Blu-ray PlayersReplies: 4Last Post: 18th Mar 2019, 21:11 -
Question About Buying A Region Free DVD Player
By jlurban6731 in forum DVD & Blu-ray PlayersReplies: 20Last Post: 15th Jan 2019, 00:11 -
I have a Sony DVP-NS55P with no region, is it a multi-region dvd player?
By albert0001 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Aug 2018, 23:13 -
Sony BDPS6700 4K Upscaling Blu-Ray Disc Player/Make Multi Region Player
By swu1 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Nov 2017, 16:05 -
Should a Region 2 DVD played on a multi-region Blu-Ray player look normal?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Mar 2017, 10:46
