ok, I've successfull made at least 10 working cd-rw's that will play back in my panasonic rv30. But, here's the part that is driving me insane.
No matter how many different conversions I do, and I have used all the conversion software, nothing will work anymore. What the hell am I doing different?
I convert avi to mpg using either avi2vcd, or tmpge, or virtual dub. I have burned with Nero, EasyCd, and EasyVcd. I have done it in both mpeg form, and bin and cue form. I have also done both pal and ntsc. The cd's look exactly like the ones that work, but the wont even read "No Disc"
So what did I do right before, and wrong now?
Thanks in advance for any help.
"What's the differance between you and a sick mallard. One is a sick duck, I can't remember the rest, but your mothers a whore!" SNL
Hmm, since I'm not you I can't tell what may be different, but he goes a try at it.
I'm asuming you're now burning to cdr's rahter than cdrws ? It is possible your player can only play cdrw's and not cdrs. CHeck the dvdplayers link above.
Second, have you encoded them differently ? You may have raised the bitrate too high or encoded them as an SVCD or other variant that your machine can't handle. Again check your compatability http://vcdhelp.com/dvdplayers.php
I do find it hard to believe you're converting to VCD Mpg with VirtualDub (it is not possible) I can only think you may be frameserving.
If the directory structure and method is identical to what you've done in the past, I am sure it's a compatability problem with either how you've encoded them or the media itself.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Thanks for the reply, I am a little confused about the bitrate part, but can't remember ever changing it. Basically, I just use the settings in Nero or Tmpge and it worked fine. I have alwyas used cd-rw's because I know cdr's wont work in my player.
Is there a link that will help me on the bitrates? If thats the problem, then there should be an easy solution!"What's the differance between you and a sick mallard. One is a sick duck, I can't remember the rest, but your mothers a whore!" SNL
Why do I keep losing my internet connection?
By Captain Satellite in forum ComputerReplies: 20Last Post: 24th Aug 2010, 20:36 -
losing audio help
By tim37 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2009, 21:45 -
Am i losing quality?
By chronic777 in forum Newbie / General discussionsReplies: 9Last Post: 26th Aug 2008, 05:57 -
Losing the subtitles
By myd in forum DVD RippingReplies: 7Last Post: 14th Jul 2008, 19:19 -
Am I losing image quality when I do this?
By Ronny G in forum Authoring (DVD)Replies: 3Last Post: 26th Feb 2008, 10:22
