hi i have bought tmpgenc 7 and i 'd like to convert from a dvd to a generic mp4 file that would play on most macs and pcs / mobiles
i'd appreciate advice on what typical settings i might chose to employ to cover most bases please
Results 1 to 10 of 10
Start with the mp4 defaults and then raise the bitrate if the quality doesn't suit you. You should also generally output progessive instead of interlaced. TMPGenc has decent deinterlacing filters which you may want to experiment with -- again, start with the default and work from there.
Thanks so much . really appreciated. three further questions if i may -
why do you recommend progressive over interlace
is would the average bit rate of setting of 8.2 be sufficient for most cases where the orig transfer was from an old vhs anyway?
and does it make a difference if i chose h264 instead of h265?
thanks again -
1. Most displays are progressive. While I'm generally an advocate of leaving interlacing be, if you're converting to mp4 may as well go the whole way.
2. 8.2 may well be overkill for SD recordings. You can try reducing it to around 4 and not see a significant difference.
3. H.264 is still more ubiquitous, so more people can easily watch it. While the encoding is less efficient, it is also generally a lot faster. -
I don't know if tmpgenc supports the x264 encoder but if it does use crf rather than bitrate. With crf encoding you pick the quality you want and the encoder uses exactly the right bitrate to deliver that quality. You can also create mp4 video from DVDs with Handbrake (free). It supports x264 (c)RF encoding.
hi and thank you all
sorry for delay in responding
there are other settings that i did not ask about in tmgenc mastering works 5 when outputting to mp4
to be on safe side, i would also love some advice on them please if anyone knows
what suggestions would you have with regarding to the profile and level (i assume the '4' referred to previously was the 'Level 4', aspect ratio (the video i've imported is 576 x 720), rate control mode and the bvb buffer size and performance sections
regards and hope well
emma -
Profile@Level: Main@3.1 or High@3.1
https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Profiles
https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
rate control: CRF
vbv buffer size usually doesn't matter if you specify profile and level.
I don't use the software so I don't know what performance settings are available. I suspect this is the x264 presets. Use medium or slow. The slower the preset the better the quality. But beyond slow there won't be much difference.
Rewrap MTS to MP4 w/o re-encoding. Why is MP4 smaller? GUI batch tool?
By Razz in forum Video ConversionReplies: 7Last Post: 13th Mar 2021, 16:24 -
FFMPEG Conversion from MKV to MP4 returns a empty MP4 file?
By lolmaisine in forum Video ConversionReplies: 4Last Post: 6th Mar 2019, 07:45 -
Split mp4 file into specified size (part1.mp4, part2.mp4 etc.)
By TubeBar in forum EditingReplies: 7Last Post: 1st Feb 2019, 22:41 -
how can i join two videos a1.mp4 + a2.mp4 = a12.mp4
By sommers in forum Newbie / General discussionsReplies: 14Last Post: 8th Jun 2017, 18:01 -
Existing .mp4 AAC transcode to .mp4 AVC
By MelRay in forum Video ConversionReplies: 2Last Post: 14th Aug 2016, 16:11
